View unanswered posts | View active topics It is currently April 29th, 2026, 11:26 am
Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 It's a beautiful day!
Post Re: It's a beautiful day!
fucked rings?
November 22nd, 2010, 8:48 pm
Ahh I think I know now, the big pipe is angled down beside the front wing, I reckon moisture is getting in there causing the mayo, can't belive I didn't think of that!
November 22nd, 2010, 8:55 pm
So the breather pipe that goes to the standard air box is just dangling now you have a racey filter on? How is the breather working if thats the case? :?
November 22nd, 2010, 11:27 pm
The breather works just the same, that pipe stop oil being spat into the atmosphere or all over the engine bay. Usually, on a race car they are routed into a catch tank to stop the oil going on the road.
November 22nd, 2010, 11:31 pm
and that would explain sometimes finding a small amount of oil in the bottom of the filter / a oily air filter?
November 22nd, 2010, 11:33 pm
ah , i thought it was fairly crucial to it working properly for some reason. :? :oops:
November 22nd, 2010, 11:34 pm
Yeh and the standard sponge filter should be oiled anyway , its supposed to be a 'wet' filter and should have a film of oil applied after cleaning.
November 22nd, 2010, 11:36 pm
If I'm honest I've never had oil exit that pipe would you belive? Having said that moisture can blatantly get up there, which I obviously didn't think of
November 23rd, 2010, 2:09 am
rebel,
if your engine breather is working correctly, gasses should only move 'outwards' through it.
My vote's with ben, who recommended that you fit the grille muff.
If you didn't fit that as soon as you should have, the engine oil will not have been reaching its correct working temperature, so water ( just one of the byproducts of combustion) which inevitably reaches the sump past the pistons won't have been driven off.
Even though you've fitted the muff now, the oil probably still has too high a moisture content.
November 23rd, 2010, 3:01 am
I see, well it's been on couple weeks now but I havnt bothered to check the breather for quite a while, I suppose it's a lesson for me really! I'm changing the filter to original tomorrow, and I'll do a oil change at the weekend. Is a couple of weeks of neglect going to cause too much damage? Bearing in mind I've used it half as much as I normally would due to a duff battery.
November 23rd, 2010, 3:18 am
