View unanswered posts | View active topics It is currently April 29th, 2026, 11:11 pm
Reply to topic  [ 30 posts ]  Go to page Previous  1, 2, 3
 Exhaust back pressure important??
Post Re: Exhaust back pressure important??
balance pipe
at L or multiple of L is where the 2 pipes join , however a smaller balance pipe near the head, there is no mention of it in the manual it assumes a 2 in to 1
as for the tail pipe ideally it again should be a multiple of L
the start of any silencer/expansion chamber should also be at L
as for the diameter of the 2nd pipe the original 2cv had a smaller bore tail pipe but it is relativley long i wonder if there is some relation sihip that if you half the bore you double the length....?
and yes its peak power rather than peak torque
and looking at yor pictures.......looks good and thats half the battle ;)
November 3rd, 2010, 8:41 am
Joolz wrote:
This is from STP, a German 2cv tuning guy who knows what he's talking about, and it answers a few questions.
http://www.citroentuning.de/doc/Exhaust ... essure.pdf
Maurice is something eh.
Love this :mrgreen:
Not minded at any one in particular, just interesting comments
What other wannabee mechanics say:
„What about exhaust systems? Well, my favorite quote is, "That system
doesn't provide enough back pressure for good low end power. You need
back pressure for good low end and mid range on the street.“
Simply put the above is bullshit and reveals more about the speaker's lack of
knowledge in exhaust tuning than anything else. He probably gives out lots of
advice like this because he likes the sound of his voice or loves to see his name in
print on forum boards. Back pressure (I assume our friend means
restriction/resistance to flow) does not "help" mid range power.
See the dyno chart examples of muffled 2CV6 engine:
November 3rd, 2010, 10:04 am
:roll:
November 3rd, 2010, 10:53 am
Anyone still in contact with Maurice, last i emailed him he was in hospital having a major surgery, heart i think, i have not heard from him in a while...?
Harley
November 3rd, 2010, 11:21 am
Harley
And you don't want to
November 3rd, 2010, 11:35 am
Forgot to add this
A very interesting article found by PUMA Race engines about experience with clients and customers.
I fully agree with Mr. Baker:
http://www.citroentuning.de/customers.html
November 3rd, 2010, 11:56 am
none of which really helps Joolz get his BM engined spesh going does it? :lol:
November 3rd, 2010, 12:07 pm
Sean wrote:
joolz
you will need some info on the bike engine and the cam duration
from the 2cv tuning manual :-
length of primary pipe(s) in inches( american formulae?) from the back of the exhaust valve=L
duration of the exhaust valve from opening to TDC in degrees=ET
anticipated revs at which max power is anticipated-(less)500rpm
so L=(5100 X ET) / (RPM X 6)
that gives a theoretical length of the primary pipe the actual exhaust pipe will need to be L less the length of the exhaust port in the head.
primary pipes can be multiples of L
diameter of pipe formula again in imperial
Cylinder cc X2
divide by 16.4 to get cubic in
divide by L from above
divide by 3.14
Sq root
multiply by 2 add 0.120
from that you add 10% or 15% due to the fact that its a contorted pipe not a sraight one.
for a standard 2cv thats:
301cc X 2=602cc 602/16.4= 36.7 cu in 36.7/L(34.8in)=1.05in 1.05/3.14=0.33 0.33 sq root= 0.57 57 x 2 + 0.12= 1.27 finally add 10% and you get 1.4in
right thats the 2 main pipes length and diameter to the point they both join together
so the primarys on a standard 2cv producing(ideally) peak power at 5750rpm would be 11/2 inch pipe 30.18 inches long or 64.8 (or keep adding 34.8)
seconary or tailpipe
is the above formula but its cylinder cc X 4(1204cc) at the start
does that help?
(and jameswallace you are banned from chipping in to this thread if your maths is anything like your grasp of English)
I have to confess a teeny bit of wee nearly escaped when I read that one... :o
November 3rd, 2010, 12:14 pm
i paassed maths with flying colours !!
November 3rd, 2010, 6:45 pm
:lol:
and went out and checked the exhaust figures on the car on the drive
tie in with the figures in the formula
November 3rd, 2010, 7:57 pm
