lpgo
 Re: Single point injection
Quote: KDFI = A German gay took a Megasquirt, ..... haha, im managed to not say anything when i spotted that on! Read what I mean not what I write. Sorry for my English it is a little wobbly, Nothing against German Gays, Guys. I'translated it to see what I did wrong, so I don't know if he is gay honestly but he is German for sure.
| September 15th, 2010, 5:54 pm |
lpgo
When you take a KDFI, you got do to ignition first, otherwise you have to change (solder) the KDFI to use the original 2cv ignition signal. Take a triggerwhee,l a Swiss gay! (ups I did it again) guy toke a 36 toothed bicycle sprocket behind his fan to trigger the ignition. Or drill 35 holes in the flywheel (1 hole free this is the start signal for the ECU) this is what I did. Don't start with throttle bodies, you don't need them for better millage, start with the original carb with a tps (throttle posotioning sensor on it). The 2cv carb is really good. Please take a good look at my video http://www.youtube.com/watch?v=_oEY5LSovEIat 1.58 min. you can see the adapted plate to the carb with the tps on it. The only difference is that my car runs on LPG (my name is Geo) =LPGO so I've got LPG injectors (the red things in the video) instead of petrol injectors. My speed went up from 105 to 120kmh on LPG injection
| September 15th, 2010, 6:15 pm |
toomany2cvs
lpgo wrote: Take a triggerwhee,l a Swiss gay! (ups I did it again) guy toke a 36 toothed bicycle sprocket behind his fan to trigger the ignition. I _like_ this approach. Pure genius. You'd have to be careful to somehow key it to the crank, though, else you'd have to re-time the fan precisely every time you cleaned the oil cooler. A bit easier on a four-pot, though, since you could fix it to the cam belt drive. Cheap, too - £13 - but would you have to be careful about getting a steel one, rather than ally, for the magnetic sensor to "see" it? Quote: Or drill 35 holes in the flywheel (1 hole free this is the start signal for the ECU) this is what I did. By a strange coincidence, this was being discussed elsewhere just a couple of days ago.
| September 15th, 2010, 6:35 pm |
Tim2cv
gym bunny
Joined: December 8th, 2008, 4:08 pm Posts: 806 Location: Burton-upon-Trent
wow, that 123/carb looks an interesting and very tidy bit of kit... shame there isnt any more information about it.
Tim
 1299cc FTW
| September 15th, 2010, 8:17 pm |
Harley
Joined: May 3rd, 2009, 11:40 am Posts: 816 Location: Melbourne, Australia.
toomany2cvs wrote: The other thing you'll need, as well as an inlet air temp sensor, is a coolant temp sensor - slightly trickier on an air-cooled engine - cylinder head temp is the usual source, AIUI. I've got a CHT sender from a '70s US-spec D-Jetronic VW 411, needs to be fitted into the head fins somehow, but not sure I'll use it - you can get ones that just screw under a plug thread. Setting the cold engine enrichment (think "pulling the choke out") is part of the mapping process, same as the injector durations etc, so the precise temperature-to-resistance curve doesn't really matter unless you're trying to use a pre-existing map.
<thinks> You could just use a variable resistor as a manual "choke", of course... I used a Buell CHT sensor screwed into an aluminium plate then grub screwed between head fins, works great. You can't use the Thermocoupler type sensors that screw under the sparkplugs with megasquirt, they have the wrong resistance, anything is possible but very diy, i use one simply as a gauge for engine temp.  This thread on Snails has lots of info, pics and troubleshooting http://snail.s4.bizhat.com/viewtopic.php?t=106&postdays=0&postorder=asc&start=45&mforum=snailHarley
samfieldhouse wrote: It is M9 for the shocks yes, the rest I'll check when next i'm underneath her. Ironically, this will be valentines day.
| September 16th, 2010, 3:14 am |
Joe
lpgo wrote: Quote: KDFI = A German gay took a Megasquirt, ..... haha, im managed to not say anything when i spotted that on! Read what I mean not what I write. Sorry for my English it is a little wobbly, Nothing against German Gays, Guys. I'translated it to see what I did wrong, so I don't know if he is gay honestly but he is German for sure. sorry, its just i am easily amused  Your english is brilliant, much better than i can read, write or speak in any other language. so i shouldn't really laugh.
| September 16th, 2010, 4:11 am |
toomany2cvs
Joe Ahvee wrote: Your english is brilliant, much better than i can read, write or speak in any other language. It's a _lot_ better than many here manage in their mother tongue...
| September 16th, 2010, 8:22 am |
lpgo
toomany2cvs wrote: Joe Ahvee wrote: Your english is brilliant, much better than i can read, write or speak in any other language. Maybe we should open a new forum with silly talk. It would be the bussiest of all !!!!!!!! Sorry I'm of topic now.
| September 16th, 2010, 12:17 pm |
Joe
toomany2cvs wrote: Joe Ahvee wrote: Your english is brilliant, much better than i can read, write or speak in any other language. It's a _lot_ better than many here manage in their mother tongue... Yes, Agreed!
| September 16th, 2010, 1:33 pm |
J-dub
Joe Ahvee wrote: toomany2cvs wrote: Joe Ahvee wrote: Your english is brilliant, much better than i can read, write or speak in any other language. It's a _lot_ better than many here manage in their mother tongue... Yes, Agreed! guilty, as charged!
| September 16th, 2010, 11:20 pm |
Users browsing this forum: No registered users and 227 guests |
