Place for switches or gauges
Edce
Joined: October 12th, 2019, 6:40 pm Posts: 164 Location: Limburg Belgium
 Re: Place for switches or gauges
@jasu : indeed, when cam and cranck are mechanically connected (I guess in all petrol engines  and the sofware allows to set the necessary triggers, a cam initiated spark and fuel should be possible.
| December 12th, 2020, 6:58 pm |
Roger V
Edce, Pete I've ordered a hot end temperature sensor as used on 3D printer. Thought I may have a play with it as engine temperature sensor. Haven't thought how or where I will deploy it yet though.
| December 13th, 2020, 10:31 pm |
Edce
Roger, the place to put the sensor is the key issue here. It should warm up not too slow, but also not too quick. I guess it would be quite a study to find such place. The oil temperature increase is far too slow, the temperature increase of the cooling air inside an airbox (around the exhaust) is in fact too rapid. The place to fix would be a plce where a stabilized temperature of about 90°C should be found. Maybe fixing a small plateof a certain length to the first silencer would the job. But as said that needs a lenghty investigation.
| December 14th, 2020, 10:01 am |
lpgo
Edce not quite true. There are 3 things going on in a 2cv engine. Oil temp, cilinder(head) temp and exhaust temp. Most true is cilinder(head temp) so that is what you want to measure. Oil is always (sometimes minutes) behind this. Most desirable to measure is the cilinder(head) temp. So put your sensor somewhere at the cilinder(head). Exhaust temp us also good to know especcially if you turbo-ed it.. But then you need some thermo coppels..
| December 14th, 2020, 11:44 am |
jasu
Joined: August 8th, 2012, 11:00 am Posts: 510 Location: Korpilahti, Finland
Sensor on cylinder head. Standard sensor from engine with Bosch injection, 7mm diameter, just made M7 thread on it... Tried some other places also, oil temp is wrong place to diagnose temp fot EFI, sensor between cooling fins was unreliable and "too fast" reacting to drive situations, that place on cyl head was best place, from my opinion...
| December 14th, 2020, 12:34 pm |
lpgo
jasu wrote: Sensor on cylinder head. Standard sensor from engine with Bosch injection, 7mm diameter, just made M7 thread on it... Tried some other places also, oil temp is wrong place to diagnose temp fot EFI, sensor between cooling fins was unreliable and "too fast" reacting to drive situations, that place on cyl head was best place, from my opinion... I agee Jasu, also a good place for a knock sensor.
| December 14th, 2020, 1:11 pm |
Roger V
Jasu That looks like what I have in mind.  Is that a coolant temperature sensor? would you have a part number? Geo I was thinking knock sensor there as well.
| December 14th, 2020, 2:33 pm |
Edce
| December 14th, 2020, 4:29 pm |
jasu
I don't have any part number, but exactly same sensor I have seen on PSA -engines (Ax, Bx, Cx, Xantia, Xm) from 80's, 90's, also BMW from same era and also from some Range Rovers from 90's and also Land Rover Discovery II -99...-02
| December 14th, 2020, 4:32 pm |
Roger V
@Jasu, this is so interesting.  So, how long has that been working? How are you displaying the temperature? What do you use for a gauge? Edit And ...... did you just put a thread on the sensor, or did you have to cut it back first?
| December 14th, 2020, 8:47 pm |
Users browsing this forum: No registered users and 209 guests |
