View unanswered posts | View active topics It is currently June 19th, 2026, 9:17 am
Reply to topic  [ 880 posts ]  Go to page Previous  1 ... 13, 14, 15, 16, 17, 18, 19 ... 88  Next
 1-2-spark
Post Re: 1-2-spark
jasu wrote:
lpgo wrote:
0 = a total vacuum
100 = normal airpressure (a 2cv with WOT = wide open throtte gives near 100)
everything above 100 is for turbo- or supercharged cars.
Don't be surprised if You get (almost) normal air pressure -reading allways when throttle is opened, noy only WOT -situation, practically in every other situation than full closed...
That was what I found, when started to use Megasquirt. It was quite impossible to tune, when MAP-reading "hit the top" allways, even when cruising at low speed...:
This is a sign that your butterfly is to big.... otherwise you can tune it easely. Even my BX-sport with 2 double carburator is running decent on speeddensity......
Are you sure you have a decent map reading or is it all over the place, then put an fuellfilter in line and a restictor .8mm (I always take a weldingtorch thingy)..
When it doesn.t work you can tune for Alpha_N or hybride
October 4th, 2012, 10:29 pm
Post Re: 1-2-spark
Is 36mm throat too big? I don't think so...
Ok, there is two 36mm throat, second start to open at 70% throttle opening...
But still, there isn't almost any vacuum when throttle is opened...
There isn't any restriction at MAP -line, 160cm hose with 4/2mm hose, very steady MAP-reading at all...
And yes, I use Alpha_N, no way to use Speed Density.
Maybe I have made everything wrong, in last five years..? Even when MS is working fine... :mrgreen:
October 5th, 2012, 11:08 am
Post Re: 1-2-spark
I guess so.......... (sorry don't want to be rude)
A) Have you set the proper Mapsensor in the settings of Megasquirt????????
B) What throttlebody are you using and where is your maphose attached I think something can be wrong there also....
Every Visa engine runs on map with the little vacuumbox (giving more advance at cruising speed.
Marks 4x4 1-2-spark ignition runs on map with Visa vacuumbox
My 1-2-spark 2cv runs on Visa vacuumbox and you can exacty point out with the throttle when the vacuumbox kicks in...
My turbo 2cv runs speed-density Megasquirt with or without turbo to 1.5 bar on boost....
Even my BX-sport runs on Mapsensor = speedensity
So yes I think you are doing something wrong.................(again don't want to be rude)
MS and 2cv works even finer on speed-density trust me I know what I'm talking about.....
October 5th, 2012, 12:23 pm
Post Re: 1-2-spark
My throttle body is 38mm from Daewoo Matiz, similar size 3cylinder engine, 28mm would be better!
I had unstable map until I put a fuel filter in line, it still bounces a bit put it is tunable. Where do you put the resistor?
Harley
October 5th, 2012, 12:47 pm
Post Re: 1-2-spark
Yes, MegaTune MapGauge reading is exactly the same, when there was another MapGauge connected.
BX 19GTi 8-valve, the older Jetronic L3 -version. Maphose is connected nearly 20mm below butterfly. There is 0,3mm hole to tube where it is connected to MAP -sensor with 160cm hole with 2mm inner diameter.
Well, there is very big difference between MAP-sensor and Visa vacuumbox. MAP-sensor gives pressure-related-voltage and Visa vacuumbox has only a switch.
Same kind of switch is used on Harley-Davidson engines, called VOES. And, same thing was find when installed Microsquirt to my friends H-D Sportster. VOES worked perfectly, but still MAP-reading was about same than normal air pressure when opened throttle-it was same if opened only little or WOT.
Please don't get confused, and talk same time N/A and turbocharged engines!
And again yes, I have also some experience with turbocharged Visa engine with Megaquirt...
That is funny thing, almost everyone who has played with Megasquirt, says the same. Alpha_N is something between very hard and nearly impossible to tune, but I didn't find any difficulty with that. With Speed Density tuning was PITA, and after changed Alpha_N tuning became so easy that it could be...
I'm only telling what I have experienced, and if someone come and say Alpha-N is the wrong way, I will ask why. And if that person can't be justify his opinion, I don't care much. That is because I have used both, and I'm pretty sure that Alpha_N is for this kind of solution, and Speed Density is when I get my supercharger on...
Lpgo, You haven't been rude, and there isn't an absolute true on these machines... 8-)
October 5th, 2012, 2:33 pm
Post Re: 1-2-spark
Harley
I've got the same in my turbo 2cv and in my opinion it is just to small and I would prefer a slightly bigger one (for a standard 2cv) for a supercharged 2cv it will be perfect.. for a turbo2cv it is to small when driving in the non-boost??? region.......
again my opinon.....
Put the resistor near the inletmanifold, put the fuel filter near the ecu...........
October 5th, 2012, 5:40 pm
Post Re: 1-2-spark
jasu
Well, there is very big difference between MAP-sensor and Visa vacuumbox. MAP-sensor gives pressure-related-voltage and Visa vacuumbox has only a switch.-)
I now this is diffrent to a mapsensor the only thing I want to tell here that a 2cv/visa has a steady mapreading switching the switch on and off at a certain vacuum, (will test this week when it switches so that I can simulate it with the onboard 1-2-spark mapsensor, its a start for me to implement a vacuumsensor, in a later stadium I will make it infinitive with programmable more or less advance, cruising along in my 2cv the switch opens at about 90kmh.
jasu
Please don't get confused, and talk same time N/A and turbocharged engines!-)
I'm not confused I have only mentioned speed-density........
jasu"]I'm only telling what I have experienced, and if someone come and say Alpha-N is the wrong way, I will ask why-)
. Because at a certain throttleposition and rpm there are more possebilities, is the car under load or is it cruising or iddeling along.
You have only 1 fuelload then so it isn.t aqurate enough. Okay on fuel it will work but on lpg there a smaller bandwidth (about 1.2 to 1.6 arf) to make the car run so it doesn't work for me.
I had my BX-sport running at the beginning at A/N, but when I drove a away for instance, give a little throttle, let the clutch come up the engine needs more fuel, but hey the throttle is at the same place so it won't get more fuel and the engine starves, doing the the same at SD map goes up engine gets more fuel, car drives nicely away......
N/Ais easier to tune for me too.....
jasu
So with supercharger suddenly SD works???? and without supercharger it doesn't...... Ahem
But hey you are right there are more possebilties here have you ever run hybride,,,
1. tabel A/N 2. table SD works great too when you have eratic map readings........
p.s. where drifting off here 1-2-Spark.......
October 5th, 2012, 6:16 pm
Post Re: 1-2-spark
Back to Knock sensor.
lpgo wrote:
notsmartcar wrote:
I would be interested in one of your kits i am no computor expert but would it be possible to run your system with some kind of knock sensor so the advance would be always a little retarded from the pinking zone
Theoreticly it is possible but in practice it is very difficult.
A knock sensor is a sort of microphone; it picks up all engine noise, what you have to do is to filter out the noise of knocking, this is for every car diffrent. You've got to have some sort of scoop to visualise all the diffrent noises and isolate the knock noise, this is usually done by the frequence of it. When a noise at a certain frequence is heard by the "microphon" (knocksensor)it has to go to an amplifier wich gives a sign (current) to the microchip and the microchip retards the ignition.
For me at the moment it is not duable (as for lots of aftermarket ignition systems) but hey thats why I came up with the tripple advance-tableswitch!!!!!!!
When you here the engine knocking you can by the touch of a switch choose a diffrent advancetable (ofcours with less advance) and the knocking dissapears, with my unit you can switch between 3 tables, so when it still knocks at the 3. table youre running on water!!!!
you can tune all 3 advance curves by yourself...... Look at the last video, where I'm setting the advance tables (in the right upper corner you see a 1 or 2 or 3 and you can see the advanceboxes change also when switching to another table.
video: http://youtu.be/c76WSwSPrRA
look at around 2.25 there you can see the switch and the diffrent advance curves
If you can give me a knocksensor and amplefier which gives a current when knock occurs I can programm the microchip that it works........
I agree with LPGO on this, HEREis a good article about how to implement a Knock sensor into megasquirt.
We all know how loud and rattly the 2cv is (a lot due to no water jacket), tuning a knock sensor and finding an appropriate place would be problematic at best. 3 switchable ignition curves that are also tunable is a perfect alternative.
The best way to test if a knock sensor is working is to hit the block with a hammer... I don't know about you but sounds like my engine is already hitting itself with a hammer!
Harley
October 7th, 2012, 8:28 am
Post Re: 1-2-spark
Ref - my 1-2 spark installed. Please see my Dyane 6.52 thread for photos
October 7th, 2012, 2:50 pm
Post Re: 1-2-spark
This evening I made good progress implementing the Mapsensor.
The pointer at my laptop screen is now moving when I suck or blow into the mapsensor and it is giving almost the reel numbers so this is great, I made a little table but it doesn't count btween 2 points it jumps from 1 point to the other. But this will far more be better already then the Visa vacuumbox.
I uploaded a little video at youtube but at the moment I can't find it; as soon as I find it I will post the link here......
Well heres the link http://www.youtube.com/watch?v=cGC12_6WKvw
It is reel stable (running dry) so this is al beyond my expectation.......
I noticed I'm reely good in sucking (almost vacuum) but my blowing sucks; only (.2) bar of boost in my longs.. (no Gay-Joe this is not what you think):lol: :lol: :lol: :lol: :lol:
I didn't dream I could make this to work so quick so I dont have a hose to test it in the car
so I will test next week......
to do list
-linear maths between two points
-writing software so that you can tune more or less advance under vacuum and boost with computer.......
October 13th, 2012, 11:18 pm
Users browsing this forum: No registered users and 215 guests
