View unanswered posts | View active topics It is currently May 23rd, 2026, 9:41 pm
Reply to topic  [ 241 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18 ... 25  Next
 All about: 2CV suspension
Post Re: All about: 2CV suspension
Well done james! i knew you would be able to do it. If you read the thread in the first place it would have been quicker though (yes that was a joke)
October 22nd, 2010, 3:27 pm
If this is dumb, my apologies - but we all have to learn from a beginning, and that's where I am with trying to understand the (Gallic?) logic/rationale behind the knife edges.
As spares, these came with our new Duck.
Even the larger of the knife edges is a really slack fit in the tie rod fitting.
Is there something I'm missing here?
And this is a really genuine query: why don't we substitute the knife edges with a cross-pin and rose joint (below): anyone out there tried it?
November 29th, 2010, 11:57 pm
What's wrong with what Citroen did with the knife edges?
They aren't meant to be a bearing fit, it doesn't work like that. The actual knife edge itself acts like a fulcrum which 'rocks' on the shackle. They don't generally go wrong, providing they are kept greased. Why change it?
November 30th, 2010, 12:03 am
I think they are made for push and not for pull!!
November 30th, 2010, 12:17 am
Big one goes at back (knife edges)
November 30th, 2010, 12:19 am
Hi all - hey, don't be too sensitive: I'm not suggesting that there is anything wrong with the original design. One of the things I was asking (perhaps I didn't make it plain) is - I don't really understand the principle involved (a cross-section drawing would help). And James - thanks for letting me know the bigger KE goes in the rear, but it still fits a slack as a p***k in a shirtsleve: is that the way it's meant to be, then?
So are the rod end fittings (with the eye) the same diameter hole front and back, or is there a smaller one for the front?
And why is our suspension so bloody noisy (crash!-bang!)? This is why I'm so interested in the topic. Thanks for the replies - keep 'em coming please!
November 30th, 2010, 12:31 am
it shouldn't be that noisy. veg oil in the suspension cans should sort most noises out
November 30th, 2010, 12:37 am
Thanks Joe - I put some spare brake fluid (it's rubber-friendly) in the cans a couple of days ago, pulled back the rear sleeves to get it in as I figure with the lean-to-the-front stance of the Duck, it'll work its way through the whole length of the cans. can't say I've noticed any dramatic improvement so far.
Cheers, Geoff.
November 30th, 2010, 12:49 am
Check some of the "oiling suspension cans" threads before adding brake fluid... I can't remember if it's recommended or not...
and veg oil is cheap!
November 30th, 2010, 12:51 am
brake fluid? LHM? it may well be rubber safe. but veg oil is way cheaper. and if it drops onto the exhaust is smells like chips! also, are you rotating the cans? that helps it get to all of the dry bits!
November 30th, 2010, 12:53 am
