View unanswered posts | View active topics It is currently June 19th, 2026, 7:50 am
Reply to topic  [ 880 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18 ... 88  Next
 1-2-spark
Post Re: 1-2-spark
As I said before, I wanna be a test driver for when you develop the vacuum advance, if that's possible ;)
October 3rd, 2012, 11:24 pm
Post Re: 1-2-spark
Yes is possible, but I think it will be december....
October 3rd, 2012, 11:27 pm
Post Re: 1-2-spark
Great stuff Lpgo!
I am looking into barometric correction, after climbing to heights of around 1400m above sea level, I can hear you laughing at that altitude but that's high for Australia! And the 2cv really started to struggle, .
1-2-barometric correction? 8-)
Harley
October 4th, 2012, 9:57 am
Post Re: 1-2-spark
Looks good!
My 1-2-Spark is still doing well and MPG is is up 15-20% despite no change in driving style.
Let me know when to book the car in for an upgrade!!
October 4th, 2012, 10:57 am
Post Re: 1-2-spark
4x4 SuperFinn wrote:
Looks good!
My 1-2-Spark is still doing well and MPG is is up 15-20% despite no change in driving style.!!
You need to change your drivingstyle then, good for gasstations....
I will; I will: your the first to hear... as told before A.T.A. december 2012...
Looks good now but is standalone in the chip now , so only map is programmed, hope it will work in a complete chip with ignition too. It is very sensible to noise (sparks etc)....... making the map readings uselless....
October 4th, 2012, 12:09 pm
Post Re: 1-2-spark
My 1-2-Spark testcar is in the local newspaper today... foto shoot last sunday
at the local meeting A t/m ZX markt......
Me at the left explaining 1-2-Spark to the man at the right, he's the boss of an industrial museum in the neabourhood (Zink h"utter Hoff at Stolberg Germany).....
Highlite of the day was a BX 4TC
to the right my BX Sport which I converted to lpg injection (Megasquirt)
October 4th, 2012, 12:15 pm
Post Re: 1-2-spark
lpgo wrote:
0 = a total vacuum
100 = normal airpressure (a 2cv with WOT = wide open throtte gives near 100)
everything above 100 is for turbo- or supercharged cars.
Don't be surprised if You get (almost) normal air pressure -reading allways when throttle is opened, noy only WOT -situation, practically in every other situation than full closed...
That was what I found, when started to use Megasquirt. It was quite impossible to tune, when MAP-reading "hit the top" allways, even when cruising at low speed...
Waiting to see Your results with that. :roll:
October 4th, 2012, 2:35 pm
Post Re: 1-2-spark
123ignition say that there is already a place in the 2cv double carb where you can install a vacuum hose, page 4 of http://123ignition.nl/pdf/2cv_manual.pdf
October 4th, 2012, 3:23 pm
Post Re: 1-2-spark
1-2 Spark arrived today ready for turbo engine. Car started first time and revs great. Will fit probably over the weekend and try it on the road. Thanks Geo
October 4th, 2012, 8:45 pm
Post Re: 1-2-spark
Harley wrote:
Great stuff Lpgo!
Harley
Barometric correction is neccecery for efi less air = less fuell
less pressure in inletmanifold = more advance for more fuellefficiency
October 4th, 2012, 10:23 pm
