View unanswered posts | View active topics It is currently November 19th, 2025, 1:04 pm
 Knife Edge wear & battered spring cans
Post Re: Knife Edge wear & battered spring cans
Maybe this solution can help getting the grease where it belongs.....
The welded suspension eyes are prone to crack. I aways check them for cracks when working on the suspension. So far I have found two, and changed them before anything happened. :roll:
Vennlig hilsen, Eirik
And a Heinemann Z412 -80
October 10th, 2009, 11:03 pm
Perhaps my understanding of the shackle is wrong, but surely the grease is needed at the contact point between the knife edge and the shackle?
October 10th, 2009, 11:06 pm
Whatever you do, the grease will be forced out of that contact point by the load on the suspension. All you can do is keep it nearby, and hope it helps to lubricate the movement.
So - put a nipple in the shaft like that, and will it do something? Well, force grease in, and it's got to go somewhere.
It can't go out of the threaded shaft end of the shackle - because that's got the tie-rod screwed in.
It can't easily get out of the sides - because of the teflon spacers/washers.
OTOH - given the visible wear on the sides of our rear shackles, those teflon washers would have fallen out long ago.
October 10th, 2009, 11:13 pm
Adrian,
it's very unusual for the shackle to have moved to one side and stayed there, so I wonder if whoever wound the suspension up so tight had wedged a screwdriver between the shackle and the hanger to limit 'rocking' as he wound it up?
By the time the rod was at 'peak tension', there was no chance of the shackle moving back towards the middle of the knife edge.
Btw, are the triangular holes in the rear hangers still triangular?
Trying to work out how contact was made on two edges of that rear knife edge... :?
p.s. Some scary pictures here of worn knife edges and shackles...
< http://2cvgb.co.uk/forum/showthread.php ... kle&page=2 >
October 10th, 2009, 11:53 pm
Can't see it, need to register as member :lol:
I have often wondered if this would work on A-models
October 11th, 2009, 10:40 am
here you go, Viking:
October 11th, 2009, 10:49 am
<stops worrying>
October 11th, 2009, 11:08 am
Thanks
Maybe made in Australia ''Drizabone'' :lol:
October 11th, 2009, 11:16 am
I like the idea of the teflon washers and grease nipple. On one of my 2CVs, I have always squished in as much grease as I could, but found the whole exercise fairly difficult. Also, I think I ended up pushing old grease with grit in it, which wouldn't help.
On the other Raid 2CV, it is not a 5 minute job, as each of the clips has the legs wired together. Much easier to pull out the pins when the car is on a hoist. Ended up using the black sticky moly grease, as I only carry one small greasegun on Raid, and that is the grease I have in it.
I have seen those ends with the rotating bush and often thought if they would be good. Trouble is I drive too hard and am not game enough to try then, just in case they broke.
John
November 2nd, 2009, 2:40 pm
John
Why not, we need a test pilot :mrgreen:
November 3rd, 2009, 1:37 am
