View unanswered posts | View active topics It is currently June 19th, 2026, 3:46 pm
Reply to topic  [ 99 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 10  Next
 Chassis in the UK
Post Re: Chassis in the UK
I know of at least three 2cv city chassis which have broken, at the front kick up. Two of those more than once. Also, I made this video of one.
http://www.youtube.com/watch?v=AjKI9R4cjtc
before you all start saying 'the engine only moves that much because it's rubber mounted' then watch the bumper overrider and headlamp bar.
I tried the same thing with one of Kens SLC chassis and it didn't appear to have any detectable movement. I don't think a Genuine one would too because of it's construction, but I've never tried so can't really tell.
I've noticed that my chassis on the Bamboo does this, it's also a cheapo one but not a 2CV city one, I was told it's a GW fabs one, but not made with box sections as Richard Morris' is, mine is folded sheet.
My own personal preference is a genuine Citroen one, preferably a 60's-70's one which don't appear to rot as fast.
September 2nd, 2009, 6:53 pm
Trouble Maker
By the end of this year, we will have our Barbour 2x4 chassis available.
It is an adaptation of our superbly strong 4x4 chassis but for everyday cars. So if your planning a raid, fancy off road or just want peace of mind then this should be for you.
Watch this space
Rich
www.barbour4x4.com
September 2nd, 2009, 7:10 pm
This is interesting.
http://www.youtube.com/watch?v=51bPwv-6fS4
I always wonder what a stiff chassis is doing to the suspension, steering and handling?
September 2nd, 2009, 7:22 pm
Blimey, Rich, that'll be impressive! Four driven wheels on a motorcycle?
Or will it be made out of a bit of wood?
September 2nd, 2009, 7:31 pm
Little Rich wrote:
By the end of this year, we will have our Barbour 4x2 chassis available.
Watch this space
Rich
September 2nd, 2009, 7:42 pm
2CViking wrote:
Interesting indeed, anyone know who's chassis those are, Mehari Cassis? It seems to suggest the galvanised version of an O.E. type chassis is stronger, anyone want to hypothesize why, could it be the galvanising is acting like a glue/brazing in the spot welded seems? or maybe just the coating adding a tiny bit to the overall thickness of the metal?
September 3rd, 2009, 12:16 am
Joolz,
as regards whose chassis, the 'cataphorese' and 'galvanise' are most probably Cassis products, with the 'origine' being an original Citroen item.
Curious that they didn't subject the galvanized version to the same maximum load as the painted version, which failed at 1250.
Or maybe they did, but chose not to show that test... ;)
Any increase in strength will be the result of the 'brazing' effect of hot dip galvanizing, which supplements the spot welds, in exactly the same manner as Renault hot dipped the shells of their Espaces to provide both corrosion resistance and enhanced stiffness.
(85 microns of zinc added to each surface of a 1mm steel sheet won't have a significant effect on its physical properties.)
Btw, the test depicted is not a true torsion test, as the positioning of the restraints on the chassis mean that both bending and torsion of the chassis can occur...
Joolz wrote:
September 3rd, 2009, 1:28 am
Actually no point in a chassis unless it is stiff, stiff as possible without being fragile, SLC is under our 2cv racer, unbeatable in handling in its day (can't be bothered with new engine regs).
September 3rd, 2009, 8:31 am
On my race car we have a genuine Citroen 2cv Chassis with some additional stiffening in places, with the springs we have on the car, the only thing that seems to stress is ME :o
September 3rd, 2009, 9:33 am
I have a Ken Hanna SLC chassis underneath mine.
September 3rd, 2009, 12:28 pm
