Joined: March 24th, 2009, 9:18 pm Posts: 248 Location: 15340 Mourjou France
Re: Ride Height Adjustment
I found out what the problem was. I'd removed the shock-absorber and disconnected the tie bar to let a friend weld quite a large hole in the floor above (one of the fail items on the CT). He had touched the thread on the tie bar - quite gently I imagine - with his angle-grinder.
So it was simply damage to the thread that stopped me doing the adjustment.
I've cleaned the thread up reasonably well and now I can do the adjustment. It takes a little more force than is strictly desirable, but it is OK. The damage isn't enough to weaken the rod.
My apologies for not discovering something more technical. I'm now slowly working round the car to get the ride height right on all four corners. Doing the front changes the back (and vice-versa) so it's a slow process.
Thanks very much to you all for the suggestions!
_________________ Dennis usually in the Cantal
1964 HY 72 (Type H, campervan) - LHD 1969 AZU 250 (formerly French Post Office van) - LHD 1982 Red Special - RHD 1983 Burgundy/Black Charleston - RHD 2017 Skoda Octavia Estate 1.4 DSG - LHD
June 3rd, 2019, 11:24 pm
Roger V
Its often something simple. It has to be for me, or I would never fix anything.
Users browsing this forum: No registered users and 220 guests
