View unanswered posts | View active topics It is currently April 28th, 2026, 5:20 pm
 Alternator id please
Post Re: Alternator id please
While your checking the electrics, you'd better do something about that 25 amp fuse too. Is it in a circuit that should have a 10amp or a 16amp? Either way, fitting a fuse that has a higher amp rating than the circuit it's protecting is a potential fire hazard.
Also, what's going on with the heater hoses?: they look as is they're crossing over each other!
Edit: I've just looked it up:
That yellow circuit fuse should be 10amp,
(blue 16amp, red 10amp).
June 25th, 2018, 10:58 am
Two Chevrons wrote:
This is my new acadiane does anyone recognise it
I think I recognise it. Did you buy it from a chap near Hailsham by any chance?
June 29th, 2018, 9:54 am
1972 dyane4 435cc
July 7th, 2018, 8:16 am
Hi Chris, no it came from up near Bristol way however I think it may have cam from there before previous owner looking at the history
1972 dyane4 435cc
July 7th, 2018, 8:17 am
Are you sure the brushes on that alternator should be fed by the remote regulator I think on that particular alternator it should be fed by a live wire through a bulb and then connected to the brush pack... I would pull the existing brush pack wire off put the bulb feed in and try that
July 7th, 2018, 9:35 am
Looks like he sold it before you got hold of it, then.
If it's the same chap, I bought my good 2cv from him in 2011, he was a bit of an enthusiast to say the least but honest. Surname T******n. I can't imagine that alternator bodge is his work!
July 7th, 2018, 4:52 pm
