Geert
Joined: July 10th, 2010, 12:35 pm Posts: 1205 Location: Magyarország
 Re: Van seat belts
Fiat Lux ... et lux erat:
My Latin is not so good.
| June 26th, 2017, 8:44 pm |
AZL57
 Re: Van seat belts
original postal van issue. There must be a tool tray too on this board if i am correct.
| June 26th, 2017, 9:40 pm |
Dennis
Joined: March 24th, 2009, 9:18 pm Posts: 248 Location: 15340 Mourjou France
 Re: Van seat belts
Geert wrote: Fiat Lux ... et lux erat:
My Latin is not so good. Genesis chapter 1 verse 1: 'God said "let there be light" and there was light..' In my case it was the flash on my mobile phone - dark barn, etc... - but it's the same principle.
_________________ Dennis usually in the Cantal
1964 HY 72 (Type H, campervan) - LHD 1969 AZU 250 (formerly French Post Office van) - LHD 1982 Red Special - RHD 1983 Burgundy/Black Charleston - RHD 2017 Skoda Octavia Estate 1.4 DSG - LHD
| June 28th, 2017, 1:20 pm |
Dennis
 Re: Van seat belts
AZL57 wrote: original postal van issue. There must be a tool tray too on this board if i am correct. Yes, that's right. Behind the passenger seat:  That's all surprisingly grubby, too. I usually keep the car papers, and a 2CV manual in there, with the wheel chock as seen.
| June 28th, 2017, 1:31 pm |
Dennis
 Re: Van seat belts
Incidentally, I'd love to know more about the van's history, but I am unlikely ever to find out.
I bought it in the UK quite a long time ago (actually, I swapped it for a DS, but that's another story), and it's quite clear that the garage which imported it used the papers and registration details from another van. The builders plate says it's an AK Series 2. This has really annoyed me from the day I found out the difference! But it's now re-registered back in France, though its papers still say it's an AK Series 2.
Obviously it isn't one of those. It's the wrong length, for a start!
But I have never been able to find the original chassis number - though I think it is still on the original chassis. I've been told to look on various places but it doesn't seem to be there. Mind you, it's all fairly oily around the engine.
It has a 602cc disk brake engine, with metal cladding not the later black plastic composite stuff. There are one or two things that suggest it may have been rebuilt by the Post Office with that engine. It has the floor-mounted accelerator (organ pedal) but the hanging brake/accelerator pedals.
| June 28th, 2017, 1:40 pm |
AZL57
 Re: Van seat belts
a friend had an old one that did have a chassisnumber near the middle seat rail. A bit to the rear. But if you have original chassis plates you can find it in the citroen archive. Costs you about 50 euros. Sometimes they even mention the dealer were it was sold new. No painted number left under the bonnet on firewall passenger side.
| June 28th, 2017, 5:14 pm |
Geert
 Re: Van seat belts
| June 28th, 2017, 6:33 pm |
Dennis
 Re: Van seat belts
AZL57 wrote: a friend had an old one that did have a chassisnumber near the middle seat rail. A bit to the rear. But if you have original chassis plates you can find it in the citroen archive. Costs you about 50 euros. Sometimes they even mention the dealer were it was sold new. No painted number left under the bonnet on firewall passenger side. It doesn't have seat rails - the seats don't slide. Both seats have projecting pegs on the front of the base that go into a series of holes in the floor, and a clip mounted on the floor at the back that can be removed to tilt the seat forward and take it out or to adjust it by moving the pegs into different holes. And it is the chassis plate under the bonnet that has been swapped for one from an AK.
| June 28th, 2017, 10:19 pm |
jasu
Joined: August 8th, 2012, 11:00 am Posts: 510 Location: Korpilahti, Finland
 Re: Van seat belts
Did those older 2cv:s even had any other numbers than what is on the chassis plate? I have been told that they became to made numbers on late 60's...
Can't say for sure, but that is what I assume there hasn't been any numbers on the chassis..?
| June 29th, 2017, 10:15 am |
Dennis
 Re: Van seat belts
jasu wrote: Did those older 2cv:s even had any other numbers than what is on the chassis plate? I have been told that they became to made numbers on late 60's...
Can't say for sure, but that is what I assume there hasn't been any numbers on the chassis..? That sounds quite possible to me. My 1964 H-Van, as illustrated, doesn't have a number stamped onto the bodywork either: just what the controle technique inspector calls a "plaque constructeur". Later vans sometimes had the number stamped on top of the passenger's wheel arch. And every time the H-Van has its CT, I get a note telling me that there's a one digit difference between that plaque and the carte grise: the number is actually 5116846 but the CG has always said 7116846. Luckily as it's only one digit I don't need to get the CG revised (and so lose the old registration number).
| June 29th, 2017, 4:56 pm |
Users browsing this forum: No registered users and 204 guests |
