View unanswered posts | View active topics It is currently June 19th, 2026, 10:00 am
 Pegged socketed threaded thing
Post Re: Rhythmic misfire
Thanks Rob
That's a huge help. :)
Not sure I can justify £40+ for a one off adjustment though. I'll see what room I have and what I can make up.
When the weather improves. :roll:
Awesome pictures :D
June 5th, 2017, 8:34 pm
Mine's an old tyre lever bent at 90°. Always worked (so far).
June 6th, 2017, 8:25 am
Yes it is the same type of tool used to undo the steering levers.
Item 26 is put in like the top covers of the pivots.
http://guillon2cv.free.fr/documents/dictionnaire/planches/slides/Planche54.html
June 6th, 2017, 5:01 pm
Thanks for posting that Fer, a great resource!
June 6th, 2017, 6:35 pm
A length of 30 x 3mm flat steel, with one end bent at 90*, works for me.
Grind or file the 'business end' to fit into the slots of the castle nut...
June 6th, 2017, 7:45 pm
Hi Admin :D
I didn't expect this 2nd subject to grow this much!
You may like to split this thread into two. ;)
June 6th, 2017, 8:54 pm
p.s. Forgot to mention that adjusting this nut will have no effect on any play which has developed between the 'sliding bearing' and the 'guide tube'.
Its only purpose is to adjust the depth of mesh of the teeth on the pinion and the rack to ensure that they work smoothly and without binding.
June 6th, 2017, 10:00 pm
ImageP1000839 by Robndaisy, on Flickr
This is the bit that wears.
June 6th, 2017, 10:23 pm
Thanks Guys
I'll try this adjustment first and see what I can achieve.
That's if I can get to it whilst in situ. I've still not had a proper look at it due to the weather. 8-)
June 6th, 2017, 10:54 pm
Post Re: Pegged socketed threaded thing
This is my problem :(
Can I gain access to this without completely removing the axle?
June 14th, 2017, 12:53 am
Users browsing this forum: No registered users and 206 guests
