View unanswered posts | View active topics It is currently April 28th, 2026, 3:00 am
Reply to topic  [ 25 posts ]  Go to page Previous  1, 2, 3  Next
 Re-jet it?
Post Re: Re-jet it?
Be careful that the new gasket has the right holes in it as many of them don't match the original drillings in the carb....
November 17th, 2016, 10:40 pm
Post Re: Re-jet it?
Dennis,
I'm not too sure where that 100 jet came from, since you only need one jet, a 107, as a replacement for the original 102.5 primary petrol jet?
p.s. Don't forget a supply of cocktail sticks, very handy when removing and reinstalling those small 'grub screw' primary jets... ;)
Dennis wrote:
Thanks for the help - especially Ken, and particularly for the explanations and the picture. My carb is marked CIT 225 so it's the later 18 & 26 mm venturi type.
I'll order the bigger jets (100 and 107) and see how it goes after that. Putting in a new carb top gasket that isn't torn in a couple of places might help too.
November 17th, 2016, 10:48 pm
Post Re: Re-jet it?
Ken - ECAS sells the larger secondary venturi jet (the 100 size one, but several larger sizes too), with the warning/suggestion:
"Jet setting is a fine art, do not move far from original."
And although at a very basic level I have absolutely no idea why a twin choke carb is better than a single choke one, I did notice that the performance on my 2CV was better when I removed a small piece of grit from the secondary venturi jet.
It's an easy change to make, and the jets are cheap, so I don't mind experimenting a little. It makes me feel as if I know what I'm doing.
Dennis usually in the Cantal
1982 Red Special - RHD
November 18th, 2016, 9:20 am
Post Re: Re-jet it?
Glad to see Ken must be drinking on a school night too - the 100 jet is the secondary jet you wish to replace - correct?
November 18th, 2016, 10:41 am
Post Re: Re-jet it?
Don't think so, Nels.
The original secondary petrol jet in an 18-26 version of a 26/35 Solex would have been either an 87.5 or a 90.
Bearing in mind that the flow rate is proportional to the "jet diameter squared", replacing an original jet with a 100 represents an increase of 23% to 30%.
Fine, as long as you're happy to waste fuel, since that will have pushed the mixture beyond the "10% richer than stoichiometric' which gives peak power... :roll:
November 18th, 2016, 1:13 pm
Post Re: Re-jet it?
Ken -
I see that ECAS also have a carb re-furb kit, which includes secondary 95 and primary 105 jets. The 95 jet apparently isn't sold separately - my existing secondary jet is 90.
So I'll get that re-furb set (and also the 107 primary jet) as I need the gaskets anyway, and I suppose that should be a better approximation?
November 18th, 2016, 2:04 pm
Post Re: Re-jet it?
tears in the lid gasket can make a marked difference
November 19th, 2016, 5:24 am
Post Re: Re-jet it?
Ken - if I've got it right about flow rates, then going from a 90 jet to a 95 one is an increase in flow rate of 11%, which is about right isn't it?
November 19th, 2016, 10:37 am
Post Re: Re-jet it?
Dennis,
see Part Number JPP02_95 for the secondary venturi jet.
Hope this helps.
Cheers, Thorsten
November 19th, 2016, 9:12 pm
Post Re: Re-jet it?
Out of interest Ken, how do you tell when a carb is at or near stoichiometric? I guess some expensive piece of analysing kit is required or do you just experiment with different jet sizes until it seems right?
November 20th, 2016, 11:46 am
