View unanswered posts | View active topics It is currently June 19th, 2026, 5:53 pm
Reply to topic  [ 11 posts ]  Go to page Previous  1, 2
 first pedal hits the floor!
Post Re: first pedal hits the floor!
lpgo wrote:
Harley it is very simple....
If you have bleed the brakes, are they working well then??? and after driving a whil they don't work well, then its probably vapor lock...
If you can't bleed the brakes well at the first place then it is probably pistons moving in to far...
p.s. ofcourse you did adjust the brake-shoes with the 14mm spanner at the backside of the drum...... did you...
Does adjusting with a vice grip count? ;)
All suggestions sound quite reasonable to me, as a suspect you can also include warped discs or flappy output shafts, or do you have a drummer?
August 29th, 2014, 5:13 pm
Users browsing this forum: No registered users and 213 guests
