View unanswered posts | View active topics It is currently June 19th, 2026, 11:40 pm
 EXHAUST EMISSIONS
Post Re: EXHAUST EMISSIONS
Citroen's 'target' setting for CO emissions at idle is between 0.8% & 1.6%.
Too low and the idle is uneven, too high and there's that pong of unburnt petrol from the exhaust. ;)
Sean wrote:
yes its a bit lean it may hesitate coming off idle
aircooled engines need to be set richer than the ideal but the emissions is so generous that if you were at the top end youd be stinking of petrol
edited so other people know what i meant as well as me :lol:
April 1st, 2014, 10:10 pm
"NOx = Oxides of Nitrogen (This is only seen by a 5-gas analyser) Only seen with dynamometer or engine under load. NOx emissions rise and fall in a reverse pattern to HC emissions. As the mixture becomes leaner more of the HC's are burnt, but at high temperatures and pressures (under load) in the combustion chamber there will be excess O2 molecules which combine with the nitrogen to create NOx"
Nelsthebass wrote:
Had two tests on Celeste and they were 238 and 302 - is the HC test one of making sure engine is burning fuel completely and therefore not emitting much NOX?
I knew it had something to do with that but obviously the wrong way round.....
April 1st, 2014, 10:22 pm
So can I leave things well alone or should I alter something? :?
April 1st, 2014, 11:08 pm
Richen the idle mixture a bit, by turning the adjusting screw anti-clockwise about 1 (or 2) turns.
It's the one which sits at an angle on the front face of the carburettor.
Afterwards, you should be able to lower the idle speed, which I'd suspect is set high to cope with the overly weak idle mixture.
April 1st, 2014, 11:49 pm
Nels,
source of that quote is here.
http://www.crypton.co.za/Tto%20know/Emi ... sions.html
April 1st, 2014, 11:55 pm
Thank You. :)
April 2nd, 2014, 12:23 am
Ken - interestingly, looking at the graph on the link, low HC is likely to give both lower NOX and, at the lower end, rich mixture - or am I reading it wrong? Granted, on a running car, only a gas analyser will tell which side of ideal you would be using HC alone.....
April 2nd, 2014, 9:29 pm
Nels,
not sure if you've registered that NOx is only created at 'high temperatures and pressures', so is not a factor which needs to be taken into account at tickover, more of a reason never to choose a picnic spot by the side of a motorway. :roll:
The primary variable in that graph is the air/fuel ratio, btw, so everything else depends on it.
Anyhow, I thought you'd be more interested to note that peak power is obtained when the air/fuel ratio is slightly rich of stoichiometric, another reason for re-jetting even if it wasn't already required to cater for ethanol and other additives in unleaded.
April 2nd, 2014, 10:09 pm
I was really meaning in an ideal world, not home tinkering at tickover - I certainly will look at enriching the primary jet on the Celeste - plugs are very pale around the tip which I believe indicates lean running?
April 2nd, 2014, 10:26 pm
Finally got round to adjusting that idle mixture screw about twenty minutes ago. Took it for a good run to get the engine nice and hot, and I can't believe the difference. Wow! I've only turned it half of one turn so far and it now picks up pace without hesitating as it did before. I might leave it well alone now as it hasn't appeared to have altered the idle speed, which is a bonus.
April 16th, 2014, 3:50 pm
Users browsing this forum: No registered users and 222 guests
