View unanswered posts | View active topics It is currently April 29th, 2026, 11:43 am
 Speedo needle is wobbly
Post Re: Speedo needle is wobbly
Tripyrenees wrote:
You can get access to the rear of the speedo if you take the battery tray out.
Which is fine if you have a LHD car...
Ah, yeah - sorry :oops:
January 14th, 2014, 4:29 pm
its not too bad joe theres quite a bit of slack on the electrical cables to pull the dash towaeds you
you have to pull the slack from the speedo cable through the hole in the bulkhead to get the dash forward enough to get ur fingers in to undo it from the speedo
January 15th, 2014, 12:05 am
My cable wasn't tightened in enough to the dash board when it did that, then it started clicking so I pulled it out on route somewhere. I didn't do a very good job of it and it rounded the end of the cable so I had to get a new one :?
January 21st, 2014, 2:35 pm
