View unanswered posts | View active topics It is currently June 19th, 2026, 7:08 pm
 help with steering joint
Post Re: help with steering joint
hi Ken - yeah I had a look (was very helpful ta) someone else had suggested finding some solid bar to fit up into my existing steering column and weld that and then clamp it into the uj, cut a groove and weld all that together also???????????????????
January 1st, 2014, 11:18 pm
This might sound a silly question, but why do you need a UJ in the column? Unless either the chassis is bent or you're modifying the upper mount to change the position, it'll add nothing to the party. Or am I missing something?
January 1st, 2014, 11:29 pm
I think it's to help in the event of a bent chassis?
January 2nd, 2014, 12:27 am
blue book requirement for racing and I am changing the seat position to slightly more central :)
January 2nd, 2014, 12:47 am
Ah...
January 2nd, 2014, 11:03 am
C15 use the same spline setup. someone in the racing Club was going to do a search for moderns that use the same shaft Dia and spline count some of the early VAG looked promising, Ford and PAS use a triangular and slotted format - probably buy in their UJs from the same supplier. Never ever heard back from him.
January 2nd, 2014, 10:29 pm
I may be wrong but I think the Burton guys told me some time that joint they use is of a visa or C15.
Maybe you could just give them a call to find out for sure.
January 3rd, 2014, 10:51 am
Users browsing this forum: No registered users and 181 guests
