View unanswered posts | View active topics It is currently June 19th, 2026, 7:07 pm
 do-llys steering has gone awry, i don,t know why
Post Re: do-llys steering has gone awry, i don,t know why
had a look at the steering today -the passenger side steering arm bolts were a bit loose the arm moved up and down a bit, yet the locking tabs were fine? :?:
anyway i tighned the 2 bolts(about a turn each) the went up the shops in it no probs
thanks for all the advise
edit :idea:
the arm was a new replacement abt a year ago i reckon it didn,t seat as it was a very tight fit in the slot- as i drove the car, in time it loosend up hence the bolts prob :?
hanged if i know :roll:
December 20th, 2013, 11:58 pm
It would be a good idea to fit new bolts,just incase they have stretched.They are high tensile,available from Ecas.
December 21st, 2013, 9:29 am
cheers dave
December 21st, 2013, 7:52 pm
edit :idea:
A good indication of a little attention with a wire brush prior to fitting and maybe a little tap or to with a Birmingham screwdriver :lol:
December 21st, 2013, 9:01 pm
i bought the arm from an online suppier banjo cost abt £50-00 i seem to remember it was a very tight fit
i used new bolts@locking tab too i had to cut one bolt off as it was too long :shock:
anyway all ok now
December 22nd, 2013, 1:20 am
They are a very tight fit,and I would still change those bolts,if they should fail,its goodnight Irene.
December 22nd, 2013, 9:28 am
ayjay wrote:
i reckon it might be the track rod end adjustment
Worth a reminder that they aren't adjustable to take up wear. The "adjustment" is only for production. As they wear, they go oval. Adjust 'em up, and they go tight when they swivel and the thicker bit comes round. Keep at it, and they may eventually snap off.
December 22nd, 2013, 10:31 pm
yes i realise that 2many2cv,s thanks for the advice ;)
cheers dave ill order 2 new bolts ;)
December 22nd, 2013, 11:39 pm
if they aren't 10.9 grade bolts they stretch
i prefer to tap out to M8 and fit 12,9s which never come loose even in situations where a welded on arm will often fail (over the rumble strips at Snet).
December 24th, 2013, 6:11 pm
Users browsing this forum: No registered users and 183 guests
