View unanswered posts | View active topics It is currently June 19th, 2026, 7:07 pm
 reniflard II
Post Re: reniflard II
I have the ye olde breather which has two of these:
Fitted under one of these:
Image.
The 'spout' should go to the air filter.
I fitted a CPD valve inline and removed the beaks which resulted in MASSIVE dumping of oil into my catch tank. I put the beaks back in and they seem to keep the oil then. The CPD valve does it's job and after 3000 miles since last August there's nothing to speak of in there.
November 22nd, 2013, 2:51 pm
Sam,
if you look at the diagram in the first post of this thread, the breather is a two-stage device, with the first chamber being where most of the oil is condensed out of the gas which is being expelled from the crankcase.
I'd guess that the original 'beak' valve provides that 'first stage' chamber on your engine. ;)
p.s. Wasn't the CPD valve doing its job, rather than it is job? :roll:
November 22nd, 2013, 5:50 pm
And at full chat/full load, which is when a 'pressurised' crankcase is going to make itself known?
Similar scenario to that of ignition timing; what's happening at tickover isn't of much importance, it's what's happening when the engine is really working for its living which counts.
I once fitted the manometer inside a car, so that it could be monitored by the passenger as the car was driven.
Anyone else tried this? ;)
Yes - but if you do not have much to start with then it is worse at full rpm. This engine had oil leaks everywhere with the old fucked reniflard but now zero leaks etc...
ChrisW wrote:
6cm of vacuum is not a lot - on mine I have 40cm at idle
November 22nd, 2013, 9:55 pm
I don"t get it.
How is "the excessive 'blowby' past the piston rings" affecting the sulprus of oil?
What's the theory?
Mind that my configuration includes an extra inline check valve.
I've Been Wrong Before.
November 22nd, 2013, 10:37 pm
Is it not that the exhaust gases passing by the rings pressurise the oil system which the breather can't cope with.....?
November 22nd, 2013, 10:57 pm
Taskos,
when an engine is in good condition, the amount of air which needs to be expelled from the crankcase during each engine revolution in order to maintain a vacuum inside the crankcase is quite small.
However, if the seal between the piston rings and the barrels is poor, there will be more gas entering the crankcase past the pistons, so the breather needs to pump more air out to maintain the same vacuum.
The air inside the crankcase will always be laden with oily vapour, and the more air that passes through the breather, the more oil that will go with it...
Don't forget that the average pressure above the pistons in a 2CV engine is probably 'around' 120 psi.
It may only reach 150 psi during the compression stroke without the mixture being ignited, but in the working cycle the peak pressure will be closer to 750 psi...
Taskos wrote:
I don"t get it.
What's the theory?
November 23rd, 2013, 12:00 am
Thanks ken.
So a compression test will reveal the actual state of piston rings and barrel?
November 23rd, 2013, 1:42 am
Hi Taskos,
almost there; a compression test is useful when assessing the general condition of an engine's top end. ( the pistons, rings, barrels and valve gear)
However a leakdown test is much more useful when it comes to finding the actual source of problems in those areas, if any exist...
Taskos wrote:
Thanks ken.
November 23rd, 2013, 2:45 am
I'll run a compression test for a start.
November 23rd, 2013, 9:23 pm
Don't forget, hot engine & wide open throttle... ;)
November 23rd, 2013, 10:52 pm
Users browsing this forum: No registered users and 183 guests
