db78
 Re: 2cv 602cc too BMW 1100cc clutch?
So gearbox breather is key! Will make sure I do this mod aswell then. Might add a drain back though so the oil pumped out drains back in.
| September 21st, 2013, 3:47 pm |
ChrisW
db78 wrote: So gearbox breather is key! Will make sure I do this mod aswell then. Might add a drain back though so the oil pumped out drains back in. Is this mod only required on BMW engines etc because of higher rpm/ top speed? Or is it recommended on normal 2cv's? Jusr wandering as never had problem with mine or previous Dyane..
| September 21st, 2013, 4:15 pm |
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2254 Location: Near Monmouth
My 2p.. 2x the Power then 2x the Heat.
| September 21st, 2013, 4:28 pm |
fritz
Joined: July 14th, 2010, 1:21 am Posts: 158 Location: Devon
Mod's done to mine:
- breather to catch tank - a good condition input shaft - shaft modified for seal (I think ken did mine when rick built it for me) - dyane diff - baffles also added although this was more for cornering - using shockproof gear oil (it's more waxy than oily) - standard valeo clutch
has been excellent and no problems so far. It only failed originally as i think gear oil was working its way up the scroll return & throwing itself over the clutch.
Rick built this for me in a very short time (I was in a rush as always) and reasonably priced. I'd recommend his services if you can't do it yourself.
fritz
| September 21st, 2013, 5:23 pm |
ChrisW wrote: Is this mod only required on BMW engines etc because of higher rpm/ top speed? Or is it recommended on normal 2cv's? Jusr wandering as never had problem with mine or previous Dyane..  On a 2cv the box will breathe through the shift tower and the small drilling in the lid make sure its clear what kills the scroll on the input is a worn pilot bearing in the back of the crank ( replacement a couple of ££ from any bearing supplier) or a failing input bearing ( again a few£ from a bearing supplier - but you do have to pull the box to its component parts to fix) once the scroll has lost its bite then high revs with a 2cv box will have oil emerging from the front of the box
| September 21st, 2013, 7:19 pm |
News to me... Anyhow, will find out soon enough as the input shaft for one of the UK entries at Spa is heading this way for me to fit a seal. Last time I fitted one for this team, they managed 3rd place using a 2CV gearbox, whereas the GS boxes they'd used previously always caused serious problems. ken fritz wrote: Mod's done to mine: - shaft modified for seal (I think ken did mine when rick built it for me)
| September 21st, 2013, 9:16 pm |
db78
Ken can you supply a seal kit?
| September 21st, 2013, 9:27 pm |
lpgo
All Mehari 4x4 front and back gearboxes have standard breathing with hoses on it; about 50cm high and a petrol filter at the end, so nothing new there... I think Sub Pete is rght here 2x the Power then 2x the Heat, so oil gets very thin and wants to escape through all holes.... ken wrote: News to me...
| September 21st, 2013, 9:28 pm |
db78
Do the french racing guys run gearbox oil coolers on there bmw/2cv's? Something I may try.
| September 21st, 2013, 9:38 pm |
lpgo
Going to Spa Franchorchamps this year (again). I'm going to take a good look at the beamers and which mods they make to them.....
| September 21st, 2013, 9:42 pm |
