View unanswered posts | View active topics It is currently June 19th, 2026, 5:39 pm
Reply to topic  [ 83 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 9  Next
 Oil breather ECAS
Post Re: Oil breather ECAS
ChrisW wrote:
2CViking wrote:
Forgot to add.
Inside paint is peeling off.
Is that paint from inside the breather/filler?
Yes
August 23rd, 2013, 7:41 pm
Sean wrote:
Damaged oil controller rings in fact worn rings won't necessarily show up on a comp test if there is enough oil to seal up the damaged bores/rings
Oil in the air box points to damaged rings (140 is on the low side especially if the other side is showing 150)
What's the vaccume at high revs pipe in dipstick everything else connected.
Advanced timing can cause a healthy engine to blow oil.
True but they are OK. I replaced the crank shaft before heading for Spain. All rings are OK
Variation of 10 PSI (max 10 %) is OK.
Full vacuum at high revs.
No advance timing and no blue smoke.
August 23rd, 2013, 7:43 pm
Variation of 10 PSI (max 10 %).
"Were" ok something could have let go?
August 23rd, 2013, 7:52 pm
Yes possible but the old original breather did exactly the same thing, hence the replacement to a new ECAS breather but to no avail
August 23rd, 2013, 7:57 pm
Interesting. Why doesn't it evaporate out of my engine? It forms an emulsion inside the filler cap and rocker covers?
It does. Some oils have a bad habit of forming mayonnaise especially underneath the breathe/oil filler cap. That is the coolest place allowing condensation.
August 23rd, 2013, 8:01 pm
I use ECAS breather on turbo and my pipe goes to a container - in about 15,000kms since fitting there is about 150cc of oil in there. These engine normally blow oil - dont they?
August 23rd, 2013, 8:38 pm
Hmmm
I thought that's why there is a pipe from breather to air filter to burn off any excess oil vapour
Boggy
August 23rd, 2013, 8:46 pm
Boggy wrote:
Hmmm
Boggy
Correct but mine is filling the air filter housing at a alarming rate.
Bypassing the housing is reducing the oil pissing out significantly. Here feeding and lubricating the chassis. Obvious the vacuum through the carburetor is partly to blame but maybe the oil breather has a design fault????
August 23rd, 2013, 9:05 pm
take the lid off unsrew the philips head screw and check there is no raged bits of metal stopping the spring reed valve from closing
but if it was the same with the last breather then id be looking at the rings and bores.
August 23rd, 2013, 9:29 pm
not really
August 23rd, 2013, 9:31 pm
