View unanswered posts | View active topics It is currently June 19th, 2026, 11:55 pm
Reply to topic  [ 23 posts ]  Go to page Previous  1, 2, 3  Next
 LED Bulb question
scared of the dark
Post Re: LED Bulb question
From memory your Joey has a connection half way down the cable - try swapping that over!
LED's will work with a lot less power than a "normal" bulb - so that shouldn't be the problem, but as Adrian says, polarity is important.
However, you won't get as much output with LEDs, they are much more directional (the best I've seen being 60deg each diode) and a normal bulb is 369, which the reflector in your JD is designed for.
If you run a 6v bulb on a 12v system, it'll just pop the bulb. or melt the LEDs. Sometimes they explode, which is fun.
If you've left them connected opposite polarity, that can kill them, depends on the reverse voltage rating, usually not very high as in theory with that type of bulb, you can't connect it reverse polarity in a standard H3 fitting.
On a side note I have a H3 bulb on a long lead for a tent light. Sorted.
</geek>
Some previous cars:
July 11th, 2013, 11:01 am
anyway - a beacon - how quaintly retro!
July 11th, 2013, 7:15 pm
Put a normal bulb in and accept that like me, you're not cut out for this shit.
July 11th, 2013, 7:17 pm
I'm just intrigued by Tigger's 369deg bulbs. A little bit wrapped round that you can glue to the other end?
July 11th, 2013, 7:39 pm
I was wondering about that, can you spread the extra 4 around the rest of it or does it overlap into a double brightness zone?
July 11th, 2013, 8:16 pm
my headlights certainly have a double brightess bit about 9*degrees its towards the bottom left on dipped
* Russ 'cmon thats primary school maths
July 11th, 2013, 11:18 pm
What a fucking idiot. 9. Was thinking days. I'm very tired and confused.
July 11th, 2013, 11:27 pm
Best check the setsquares at work, in case they're 91.25 degrees? ;)
July 12th, 2013, 1:07 am
Probably because old calendars (such as the Persian Calendar) used 360 days for a year - when they watched the stars they saw them revolve around the North Star one degree per day. That shit ain't by chance... :ugeek:
HArley
July 12th, 2013, 4:28 am
scared of the dark
Caused by the spinning effect on the light.
Not thinking fourth dimensionally etc etc.
In the fourth dimension you find people who can't type for shit.
Some previous cars:
July 12th, 2013, 10:49 am
Users browsing this forum: No registered users and 236 guests
