 smoky start
Post Re: smoky start
Thanks for the answers, you're all right. I don't think it's anything major - I'm just a bit OCD (you should have seen me whenever a warning light popped up on a CX, and it's the main reason I got rid of my C5). Started this morning with no smoke, so probably the rings lining up. I'll try and sort the sender though.
My main shame is it only did 1500miles between MOTs!
June 9th, 2013, 10:27 am
Update time.
Oil pressure switch came back to life, was just dirty connections. The smoke is down to leaking pushrod seals.
June 18th, 2013, 1:49 pm
so how does the oil leaking out of the engine via the pushrod seals ( classic CPD failure symptom BTW) cause the puff of smoke on start up?
June 18th, 2013, 10:48 pm
As the man said "Just like that!"... :roll:
June 18th, 2013, 11:59 pm
I am wondering about that too? Co-incidence or Tommy Cooper?
Anyway in typical sod's law fashion the thing didn't puff smoke after I'd called the garage to book it in. :lol:
It's going back together now and Pete's going to give ecas a call and see whether he can get a cpd valve.
June 19th, 2013, 9:42 am
Maybe Richard meant valve stem seals, which can give smoky starts. I am surprised no one suggested these before (or they did and I missed it?).
June 19th, 2013, 11:15 pm
No idea - as everyone can tell, I'm more of a point to a problem and pay someone to fix it :)
June 20th, 2013, 8:40 am
Thanks god for saurus
Valve guide seals 100%
normal on new especially (1990 year ) engines i have done loads of them
fit a rubber type for good results
so stop pissing around with oil pressure ideas and think in a logic way
Pony
June 20th, 2013, 11:38 pm
Pony
There's no need to be rude.
Oil pressure switch changed as sometimes it lit and sometimes not. Co-incidental with oil / smoke issues not causal. For £7.50 it's hardly a great expense.
It seems the long cylinder head studs at the back were not as tight as they could be. No idea why they were working loose though. Tightened up, new seals and gaskets and heads lapped just to be sure. New CPD valve ordered from Roy, again just to be sure.
I hadn't noticed any oil leaking, but it was very clean so looking on the ground didn't show any marks. But there was enough around apparently to coat the crossbox.
June 21st, 2013, 11:43 am
Any oil leak is blown around by the engine fan that together with forward motion tends to coat large areas. I've a leak or at least I get some oil blown around the engine bay,but even after the long 2 up well loaded blasts from Staffordshire to SW France the oil level has hardly dropped so I'm not worried.Yes there's the odd drip under the car but not enough to cause me any concern. Mind having owned british bikes oil drips/puddles are something you learnt to live with :-)
June 21st, 2013, 1:07 pm
