View unanswered posts | View active topics It is currently June 19th, 2026, 11:57 pm
 180mm Clutch...
Post Re: 180mm Clutch...
lpgo wrote:
2CViking wrote:
What is wrong with a 2cv clutch :roll:
And it burns, burn, burns,
The ring of fir, the ring of fire.
Johny cash
Whats a curry got to do with it :lol: :lol: :lol: :lol: :lol:
May 6th, 2013, 10:22 am
The amount of splines does not mean it fits, you also need to check the different profiles of splines used, old valeo catalogues (maybe new too) are very useful.
Harley wrote:
More research!
Cluch sizes are often written 180*125*18*20.6
Outer Diameter: 180
Inner Diameter: 125
Number of Splines: 18
Spline Outer Diameter: 20.6
So I discovered that...
Kia Pride clutch is:
Diameter: 180mm
Spline Inner Diameter: 17mm
Spline Outer Diameter: 19.2mm (others state 19.1mm)
Pug 206:
Outer Diameter: 181.5
Inner Diameter: 127.4
Number of Splines: 18*1.0583*37.5°
Spline Outer Diameter: 19.5
SUZUKI ST90
Outer Diameter: 180
Inner Diameter: 125
Spline Outer Diameter: 20.3
Citroen C2
Outer Diameter: 180
Spline Inner Diameter: 118.3mm
Spline Outer Diameter: 20.8
Can anyone measure an A series input shaft for me please!?
Cheers,
Harley
May 7th, 2013, 1:39 pm
Yes, I've been looking at how to calculate the spline pitch, do you have access to an old valeo catalogue Roy?
I have measered an internal clutch spline:
20mm od
18mm id
Or within a bees dick.
Each top and bottom of spline is close to 1mm
Harley
May 7th, 2013, 2:11 pm
I have followed your lead and come up with this info:
    Engine Code A06/635,M28,M28/1
    Transmission Type Manual Transmission
    Transmission Type 4
    New Part
    Hub Profile 18x17,8x20,3
    Diameter 1 [mm] 160
    Diameter 2 [mm] 160
    Version CP
    Number of Teeth 18
No other Citroen 180mm clutch has this profile... they are all 18x18,2x21 :-(
I'll keep looking though!
Harley
May 7th, 2013, 4:50 pm
I think I have found it...
Clutch kit R1166N
Clutch plate dimensions (mm): 180 x 18T x 20.3
I can't find the smaller diameter of the spline listed anywhere but it has to be close right!?
Found on 1.0 Ltr Suzuki F10A engines from 1980-2000, $AU133 Kit delivered...
Guess i'll try then return it if its the wrong spline!...
Harley
May 7th, 2013, 6:39 pm
I checked splines today
so it is like this
2cv 19 9mm od spline +or- 0.05
Ax saxo 20.1 so small but 0.2 difference is enough for non fit!
pony
May 7th, 2013, 8:56 pm
can't you just rivet an old 2cv centre boss (Valeo) on to the friction plate of choice?
May 7th, 2013, 9:07 pm
I have wondered aboit this, have heatd it suggested but I have not found anyone who has done it...
What do you think Louis is it possible to swap the clutch center boss fon the 2cv clutch to the AX/Saxo one?
Harley
May 8th, 2013, 6:45 am
