 Re: Oil leak
You'll have to measure the crank journal as it may be a re-con one fitted with a standard seal.
does the tag on the engine say "Exchange standard"?
| April 3rd, 2013, 5:50 pm |
Roger V
Joined: March 21st, 2013, 12:04 am Posts: 1655 Location: Exeter, Devon
 Re: Oil leak
Glad I looked at the breather. I took it apart with an angle grinder around the band. The 2 halves were a little stuborn to separate. The actual valve plate was a complete arse to get out. Turns out it was rusted in. How the f@#k can it have rusted with all that oil. The rubber flap was in 3 pieces and not attached. I'll edit and add an image, when I work out how  Another question if I may Would this fault actually cause the front oil seal to allow oil past in sufficient quantity that it would literally run off of the sump
| April 3rd, 2013, 7:27 pm |
ChrisW
 Re: Oil leak
Yep as casing is now pressurised instead of sucking it back in. With mine it was oil everywhere and afterwards no oil. I was having oil coming out from behind the points (no seal there only spiral on camshaft). With a Visa engine I had - same fault - the oil was coming out of the dip stick (shorter and mounted into the engine in different place on Visa engine) I know they are not cheap but I bought a Filler assembly from ECAS which has a steel reed valve in it and everytime you fill with oil you inspect the reed valve and last for ever (buy new reed valve if there is a problem). With the standard one you can not see what is going on.... They said to last 5 years but do they????? Do not buy second hand ones - look shiney on outside but inside could be ..........???????
| April 3rd, 2013, 7:32 pm |
Roger V
 Re: Oil leak
Thanks Chris
So .... if I solve the pressure issue, do I still have to replace the seal ....
| April 3rd, 2013, 7:42 pm |
ChrisW
 Re: Oil leak
I would if the engine is out it seems false economy to put it back in without.
| April 3rd, 2013, 8:12 pm |
Roger V
 Re: Oil leak
Quote: You'll have to measure the crank journal as it may be a re-con one fitted with a standard seal. Sean Good point. That would make sense. Bertie would not have know that and would have fitted a standard one. Of course, it could just have been a standard one damaged when fitted. I've done that before.  Hey ho ... onward and upward
| April 3rd, 2013, 8:59 pm |
 Re: Oil leak
Roger V wrote: Would this fault actually cause the front oil seal to allow oil past in sufficient quantity that it would literally run off of the sump  yes a faulty breather can have the oil spewing from most orrifices worse if the rings are gone. have you any way of checking the compression? id hold off doing the rear oil seal till you know the state of everything else as its an engine out flywheel off job. EDIT - over advanced timing ads to the case pressure as well as heating the oil and hardening the seals.
| April 3rd, 2013, 9:08 pm |
Roger V
 Re: Oil leak
Quote: id hold off doing the rear oil seal till you know the state of everything else as its an engine out flywheel off job Thanks Sean However, the engine is out, the flywheel is off. The engine is current occupying part of my kitchen floor (yes I am single ... well separated any way.... can't think why  ). I believe when Bertie rebuilt the engine he put in new seals. It looks like a new seal and looks like it is in straight. So hoping it is the pressure and not a damaged or incorrect seal. I think I will repair the breather and see how I feel about it. Regarding the bores ... they are unknown. Though I believe Bertie did mention them in a thread somewhere. Thanks again
| April 3rd, 2013, 9:40 pm |
dave 411
Joined: August 19th, 2010, 10:44 pm Posts: 1815 Location: Cardiff
 Re: Oil leak
Sean wrote: Roger V wrote: Would this fault actually cause the front oil seal to allow oil past in sufficient quantity that it would literally run off of the sump  yes a faulty breather can have the oil spewing from most orrifices worse if the rings are gone. have you any way of checking the compression? id hold off doing the rear oil seal till you know the state of everything else as its an engine out flywheel off job. The engine is allready out,so he might as well do it,dont you think? Now,what else should be done while the engine is out? STRIP AND REBUILD  yes,yes,yes,then its all done.
_________________ [img]http://i1207.photobucket.com/albums/bb480/alastairsmith999/dave411-5.png[/im g]Horizontally Opposed
| April 3rd, 2013, 9:43 pm |
dave 411
 Re: Oil leak
Who would rebuild an engine and not fit a new breather
| April 3rd, 2013, 9:44 pm |
Users browsing this forum: No registered users and 14 guests |
