 Tank sender
Post Re: Tank sender
Viking,
reckon you've got that '@rse about face', as the resistance should be at its lowest when the tank is full. :lol:
I tested 4 new senders the other day and they read under 15 ohms when 'full' increasing to about 340 ohms 'empty'...
2CViking wrote:
Viking,
yes, it is just a variable resistor, so there's a possibility it would work, but I don't have a value for the 'empty' resistance of a 6 volter. :(
IIRC, for a 12 volter, it's 'around' 300 ohms on empty falling to zero ohms when full.
2CViking wrote:
Would a 12 V tank sender work on 6 V? Is the unit no more than a resister controlling the earth?
Viking
It worked. I fitted a 12V sender in the tank with 6V. Needle on the fuel indicator working well. Tested the 12V on the bench, showing max 190 ohms on full, slowly moving down to 0 reaching empty.
March 23rd, 2013, 2:59 pm
Ya bugger, the other way around 0 ohm on full but still ''only'' 190 ohms on empty :mrgreen:
March 23rd, 2013, 4:10 pm
Thought you'd got hold of an export model for down under, where gravity works in the opposite direction... :lol:
March 23rd, 2013, 4:38 pm
Gravity is not working. Can't get more that this (tested 3 sender units)
Going beyond 193 it will drop to 0
How did you get 340 ohms?
March 26th, 2013, 10:46 am
Forgot to add this.
This is what the sender looks like inside. Don't know if the wiring is specific to 12V ? It works on 6 V
March 26th, 2013, 10:48 am
