 Dead dash light
Post Re: Dead dash light
Done both
Tested both in the foglight circuit. Was fine
March 11th, 2013, 11:45 am
There are fuse and a switch in line...
I've Been Wrong Before.
March 11th, 2013, 12:12 pm
I checked all fuses on the bulkhead. All fine and dandy. This is the only electrical thing not working.... So cant be a fuse..? Unless theres another hidden??
March 11th, 2013, 1:30 pm
Is the earth through the dashboard screws ok?
March 11th, 2013, 2:37 pm
This is fed by the same fuse/circuit as the side and tail lights,from your light switch,which I guess you already know.Unless you want to pull out the dash to get at all the wiring,maybe the easiest way is to run another feed in from the light switch :-)
March 11th, 2013, 2:45 pm
Or even use the spare "on-with-ignition" feed so you have it lit all the time.
March 11th, 2013, 4:20 pm
While your delving about behind the speedo stick in an LED bulb so you can actually read the speedo at night :-)
March 11th, 2013, 6:30 pm
