View unanswered posts | View active topics It is currently May 2nd, 2026, 2:12 am
 how to replace king pins cheaply
Post Re: how to replace king pins cheaply
So, how exactly are you saving money as when you buy a new king pin it comes with all the new bushes shims top and bottom plugs, just replace the lot. You could always save a few pence by greasing them every 3000 miles instead of 1000 ;)
February 23rd, 2013, 11:22 pm
hi ,
there were a set of new bushes on ebay minus the pin
bro bought them for about £8-00
we used the old pin
we checked its diameter with a digital micrometer
it is exactly the same all along
flew through its mot
February 24th, 2013, 12:41 am
Run a bead of weld round the eye in the arm, job done. Cost, less than 5p in gas and wire.
February 24th, 2013, 8:53 pm
the eye is fine russ
it was the bushes that were worn
February 24th, 2013, 10:44 pm
ayjay,
if the pin was still fine, it's more than likely to have been one of those dodgy kingpin sets which were around a while ago.
The internal diameter of the top bush was somewhat 'variable', to the extent that there could be more play in a newly fitted one than one which had been in use for years. :roll:
Moral of the story; always drop the calipers on a kingpin set before starting to fit it...
February 24th, 2013, 10:52 pm
thanks for your info ken
February 25th, 2013, 1:40 am
Users browsing this forum: No registered users and 144 guests
