View unanswered posts | View active topics It is currently November 20th, 2025, 3:19 pm
 New rear shoes on drums howling - HELP!
Post Re: New rear shoes on drums howling - HELP!
tim you do have eccentrics on the lower pivots cant see any sign of them in the photo
and they are proper eccentrics not those "missing the point completely" concentric ajustment dohdahs? the hex head should be on top of the shoe web and be under the locking tab thingy
you are fitting the drum to full torque( or till there is no give in the bearing) ajusting the 14mm hexes on a downward rotation till the drum starts to drag removing drum then ajusting the bottom of the shoe to the same as the top bit? you can usually see the high point as it will have a slight glaze from the drum
have you had the cylinders off? it sounds like the system needs bleeding and a check that the pistons aren't retracting under the tension of the dust covers
February 5th, 2013, 11:16 pm
gym bunny
Hi, yes I have the eccentrics as far as I know they are the propper ones. I'll try Seans method of adjusting them tonight. I have been doing up the 44mm nut with the breaker bar but not peening over incase i had to open them again. (Expensive nuts)
I have fitted new cylinders and will try the tip that the haynes says about leaving them loose until brakes pressed to centralise I guess?
How do you stop the dust covers pulling the pistons back in? I will get my wife to help bleed the brakes later.
thanks
Tim
1299cc FTW
February 6th, 2013, 9:03 am
a smalll spring about the same as you get inside the rear light cluster you have to dismantle the cylinder though.
as you have to get the shoes so they are practically touching any lip on the edge of the drum will hamper things as its not the actual braking surface you can reduce it with an angle grinder flap wheels are softer than hard disks and polish as they go - dont go tonto on its ass
ive never bothered centering the cylinders they are by their nature self centering
you do have the shoes round the right way and the friction material is already shampfered so tick those off the list
February 6th, 2013, 9:40 am
gym bunny
3rd time lucky... have had another go taking on board all the comments, initial short thrash round the block appear ok. (much better) Will take her to work and see if they are really fixed tomorrow.
Thanks
Tim
1299cc FTW
February 6th, 2013, 8:15 pm
