View unanswered posts | View active topics It is currently May 2nd, 2026, 2:07 am
 Oil cooler cleaning
Post Re: Oil cooler cleaning
James,
make that a soft toothbrush.
Best way I've found is a paraffin gun (or old spray gun) filled with petrol, followed up
with the air blow gun.
A pressure washer is definitely out, as that's the quickest route to distorted fins.
Jameswallace wrote:
Thanks boys
I hae some gunk at work. Ill use that and a toothbrush
Shall report back.
Thanks ken
I have a parrafin gun so may well do that !
Thanks
January 28th, 2013, 12:47 am
Hi James,
don't forget ipgo's comment regarding using the blow gun from the gearbox side of the oil cooler.
The gunge is usually caked onto the intake side of the cooler and it's easier to send it back from where it arrived... ;)
January 28th, 2013, 1:09 am
2CViking wrote:
ayjay wrote:
i posted the same question a few weeks ago, ken repled that its very important to keep them clean or the oil can overheat on long runs
compressed air and a good attatchment to blast the crud away is good
No not in temps below 0. Ask the Finnish, they block the oil cooler completely during winter and their engines never suffer from over heating. Yes if the temp crawls above +5
At Spa too they had them fully taped up.
When cleaning mine, I use that foaming aerosol gunk and the air gun.
January 28th, 2013, 2:29 am
Best way I've found is a paraffin gun filled with petrol,
No need to get racist Ken, Viking was just using them as an example :lol:
Harley
January 28th, 2013, 2:33 am
Aerosol degreaser from the front and a soft brush, then I use a garden hand pumped spray from the back to blow the much out with hot water. Has kept mine nice and clean with no overheating driving across France in the 90+ heat.. :mrgreen:
January 28th, 2013, 2:43 pm
Users browsing this forum: No registered users and 123 guests
