View unanswered posts | View active topics It is currently May 2nd, 2026, 2:07 am
 Carb Issue
Post Re: Carb Issue
Rhythm Thief wrote:
Scooters use M7 fixings apparently. Otherwise they're quite tricky to get hold of.
Try (my website!) here: http://www.retrospecparts.com/101-fixings
I've got M7 nuts and a few other bits and pieces.
January 28th, 2013, 9:21 pm
Post Re: Carb Issue
Citroen do like to use strange sizes like M7 & M9, and these are hard to get hold of other than from a 2cv specialist.
The nut on that bit of carb is more likely to be M4 or M5 though, and they're very common, you'll probably find a box of them in the local bricolage.
January 30th, 2013, 1:11 am
Post Re: Carb Issue
Joolz,
you've got to blame Solex (carb folk) for that one, not Citroen.
M8 x 1, plus it's a half nut to add insult to injury... :)
January 30th, 2013, 2:44 am
Post Re: Carb Issue
That was most definitely the problem ( I know it should have been more obvious) and now after several days of testing it starts first time every time.
I have done a basic tune up of the carb but is there anywhere on here that shows a step by step on get the mixture correct as well as the timing.
Also, how do you figure out rpm when it says in the instructions "adjust to 650 rpm etc etc" Is it just a fell, i.e very slow chugging :oops:
Thanks for the help - another snag sorted.
February 1st, 2013, 1:16 pm
Users browsing this forum: No registered users and 123 guests
