View unanswered posts | View active topics It is currently May 2nd, 2026, 2:12 am
 sloping troubles :S
Post Re: sloping troubles :S
ayjay,
I hope you'll forgive me for suggesting that this particular problem might involve a visit to el médico. :lol:
ayjay wrote:
if the level of fuel within the bowel is too low, that may cause starvation when
enema time ken :)
December 6th, 2012, 2:03 pm
It's worth thinking about that short fuel pipe that connects the pick up from the tank to the long nylon pipe,if that's split then you get problems with fuel delivery.It's a case of dropping the tank to get at it.
December 6th, 2012, 4:32 pm
lovin' the snatch
thats also something, but then why would it only cause a problem when on a slope?
last night i backed down a driveway which goes to a field, nose in the air, and she began to run fluffy, however didnt cut out after a few seconds she sat there and chugged for a good few minutes still running but ever so lumpy to the point where the oil press light was flickering away, however i ran her on choke for a few seconds and she then ran perfectly without it for about 10 minutes... then she started running lumpy again!
then after a 6-8 mile drive back to a friends house and then home, when parked up on the kerb she literally started running lumpy within a few seconds of parking up and cut out within 20 seconds of parking...
|-|-' 602 For Life :)
Keep Them Looking Standard.
1979 Myosotis Blue Dyane6
1986 Sunrise Red 2cv6
December 6th, 2012, 6:10 pm
You could test it with a gravity feed fuel tank.
It would eliminate the tank, piping and fuel pump as the cause.
If it's still a problem then you know it's the carb itself.
December 6th, 2012, 11:55 pm
Or maybe, possibly the last person to have had their paws on it?
"i did have the top of the carb off a couple of weeks ago and gave it a clean out and its only since then that she's started misbehaving! "
[quote="Diesel Dave"]You could test it with a gravity feed fuel tank.[
If it's still a problem then you know it's the carb itself.[/quote]
December 7th, 2012, 1:54 am
You didnt knock the pin (are there pins holding the float on a 2cv?) holding the float that also acts as a hinge? If so the float could be 'floating freely'?
Stab the dark!!
December 7th, 2012, 12:24 pm
Maybe stop parking it on the kerb? ;)
Constant source of annoyance round here is those that seem to think it's ok to block the pavement to avoid causing minor inconvenience to other car users. I always try and make a point of knocking a wingmirror when walking past. :)
December 7th, 2012, 7:18 pm
And I thought you were such a pleasant young man when we met......
December 7th, 2012, 8:31 pm
lovin' the snatch
haha RT ;) well with 4 of us in the house and 3 that drive... theres always a car on the drive, a transit on the kerb which i'm usually parked with.. i used to park on the lawn next to the drive but the grass has since perished...
the problem is definitely fuel related and only when the car isnt flat... i took a different route home from the workshop which involved a steep downhill - fine and then a steep uphill... hit the bottom at around 65-70 and the second i started going uphill the power just "dropped off"
debating dropping the tank on sunday and checking the top pipe!
December 7th, 2012, 10:42 pm
Managed to replace that small piece of rubber tubing by lowering the tank just a little on a trolley jack (with a small plank on top) and getting my hand in from the left hand side.
It helped that I have smallish hands and am left handed.
Just remember where the plastic spacers and washers go when you bolt it back up.
John Jordan
December 7th, 2012, 10:48 pm
Users browsing this forum: No registered users and 144 guests
