Headlamp switch so hot it's on fire?
Joolz
 Re: Headlamp switch so hot it's on fire?
Assuming that every thing is working as it should, and the switch has no more current going through it than citroen intended, can you work out precisely which bit is generating the heat, there must be a high resistance point in it somewhere. It's most likely the contacts, but could be a bad connection either from one of the wires or something internal.
| August 14th, 2012, 11:18 pm |
J-dub
This might be no help but i burnt my old loom by bridging the wrong things Now sporting a non dim dip era loom with relays to take the load of the switch for the halogen bulbs and just upgraded the wire feed to headlights
| August 15th, 2012, 12:12 am |
Sean wrote: t Joolz he'se all yours now, im off to bed so youv'e got 10 mins till "Shut the F##k up"
| August 15th, 2012, 12:28 am |
Users browsing this forum: No registered users and 7 guests |
