View unanswered posts | View active topics It is currently November 20th, 2025, 3:18 pm
 brakes----
Post Re: brakes----
Or jack one rear wheel at a time off the ground, then adjust one of the snail cams until the shoe is close enough to the drum to indicate whether the drum is out of round.
( Edit. Don't forget to back off the adjustment afterwards, though... )
If you had an assistant available to press the brake pedal gently, that should work just as well.
Fwiw, I find that it's usually drum brakes which cause this sort of problem, with over-tightening of rear wheel nuts sometimes to blame on A series vehicles.
ayjay wrote:
thats a good idea devils ad-- that way i can find out whether its a rear brake problem, rather than the front :idea:
i,ll give it a go and post back
August 15th, 2012, 4:49 pm
Post Re: brakes----
thanks ken- i,ll get to the bottom of the prob thanks to all the help on here
August 15th, 2012, 6:25 pm
