View unanswered posts | View active topics It is currently November 20th, 2025, 6:04 pm
Reply to topic  [ 28 posts ]  Go to page Previous  1, 2, 3  Next
 Ignition setting on raised compression - knocking
Post Re: Ignition setting on raised compression - knocking
Short plugs, but without the original Citroen cups (spacers). There were very small marks on the plugs and on one piston (visible through the hole at TDC), I used copper washers to raise the plugs, but nothing's changed.
Now I wanted to make sure about the rocker shaft bolts etc., so I backed off the head stud nuts, checked the peg bolts then began tightening the stud nuts again. And the left side upper rear stud broke before I reached the correct torque. I was using a good torque wrench and thightening the nuts gradually in the correct order, so it must be just my effing luck...
April 26th, 2012, 5:44 pm
could have been the knocking if the stud had stretched and the head was chattering
very good English by the way puts us natives to shame
April 26th, 2012, 8:06 pm
I'm not happy about the broken stud, but I thought it might have already been weakened yesterday, and the cause of all this. We'll see when I manage to put this thing back together. Fortunately, the stud broke around an inch outside the engine block, where it's thickness changes, so getting it out shouldn't be a problem. But I still have to find a replacement, and that's not so easy...
P.S. Thanks :)
April 26th, 2012, 9:33 pm
Hmm,
a long stud weighs about 72.8 grams, so with one to use and one for luck, posting to Poland should be around £2.
What do you reckon? ;)
Ken
P.S. Thanks :)
April 26th, 2012, 10:24 pm
P.S. Thanks :)
whats your history? nobody talks in Inches unless they grew up in the UK or spent too long working with plumbers :lol: ( or >shudder< the luddite Americans ;) )
there's an offer from Ken you cant refuse.
April 26th, 2012, 10:43 pm
Hmm,
Ken
If I can't source it from one of my polish 2cv friends, I'll seriously consider it, but time is of the essence as I've got a whole week off coming :) Thanks for the offer.
I can "think in inches" without actually forcing myself to recalculate from metric when I approximate something, these units make just as much sense in everyday use. But fractions are a nightmare. To me 3/16" is not 3/16 of what I know as an inch, but rather 3/16 of 25,4 mm, so those are a bitch to recaluclate in my head ;) If I want to express a precise dimension, I need to use REAL units ;-))
April 26th, 2012, 11:17 pm
Because it was the simplest solution for me, I decided to machine a new stud out of high grade steel, installed it in the engine yesterday. The rattling is gone now, today I reattached the wings etc. It runs great and my plugs are finally grey-brown instead of oil clogged black ;) I also changed them to NGK BP7HS as advised here. Will try to get a size 107 primary main jet and see what good that does :)
Thanks to all of you for the help :)
May 1st, 2012, 8:22 pm
Should not have a p in it
Should be b6hs, or b7hs
May 1st, 2012, 8:32 pm
Doesn't really matter, properties are all the same except for the projected insulatorr nose (from what I understand, just slightly longer around the electrode).
By the way, the NGK catalogue I looked at lists BP6HS plugs for 2cv as standard, not B6HS.
May 1st, 2012, 8:39 pm
In my experience a BP... plug creates a slightly noisier engine, which may mean less power.
May 1st, 2012, 11:51 pm
