View unanswered posts | View active topics It is currently May 2nd, 2026, 3:34 am
 Out of ideas..
Post Re: Out of ideas..
Ok I shall try that one in the morning, I'll update after, thanks
March 4th, 2012, 9:24 pm
just take it to Sean,he'll fix it :D
March 4th, 2012, 9:44 pm
sounds like your foo foo valves stuck open.
March 4th, 2012, 9:45 pm
if it were also pissing oil that'd be a good call
March 4th, 2012, 11:24 pm
still no better :'( im going to change the block/gasket that the carb sits on, just to try it..
March 5th, 2012, 12:56 pm
Right, been out in the lovely cold wet weather on this fine evening, tried everything previously mentioned and still no luck, so.. dad gave me permission to fit the carb off the front engine of the jeep, so i did and it works! took it out for a run with no problems. having said that im not going to count my chickens just yet as his car played up on friday. so it turns out both the carbs i have are faulty. i knew one was as the 2nd choke spring had broken but the other base must be faulty too...
March 5th, 2012, 10:10 pm
Users browsing this forum: No registered users and 108 guests
