View unanswered posts | View active topics It is currently November 20th, 2025, 6:04 pm
 123 ignition
Post Re: 123 ignition
I recently fitted a 123 and carefully followed the static timing instructions. When checked on a strobe though it was nearly 2 teeth out.
But fortunately it completely cured the points scatter where I could see 2 definite teeth as in the pic below (which is a mock up of how mine looked with the old points set up when checked with a strobe).
January 24th, 2012, 5:39 pm
I think Bugster means that he set the timing for the 123 by lining up the dots as per the insructions,Static,then when he checked it with a strobe,dynamic,it was 2 teeth out.Mine did the same thing,I just used the strobe to set it at max. Advance.Sorted.I think Bugster did the same :)
January 24th, 2012, 6:47 pm
Sean,wheres your reply gone?My reply was to your reply,which was a reply to Bugsters post,now its gone :o
January 24th, 2012, 6:49 pm
1 more time
STATIC is for when the the engine is STATIC ie stopped, switched off not mooving - bleedin dead
As soon as it starts the ADVANCE advances the timing and so you get the second mark.
Dont mix and match your timing techniques - if you have a strobe set the max advance with that, I have yet to see any reason why static should be the preffered method other than you can do it in a field with a tent peg. :lol:
dave - calmed down a little :lol:
January 24th, 2012, 6:54 pm
Couldn't have put it better myself dave Image
January 24th, 2012, 6:55 pm
Sorry guys,how did you get the laughing man Bugster?
January 24th, 2012, 7:10 pm
You can find them all here
http://www.runemasterstudios.com/graemlins/
Just copy and paste the code into your reply Image
January 25th, 2012, 12:20 am
Thanks Bugster,,,,,luv em'
January 25th, 2012, 9:06 am
123 is shit. No, it's really shit!
Charging issues on the van meant that it wouldn't run because the battery was getting a bit low on power. Points and condensor will be fitted soon.
Tonights recovery truck was cool though thanks to Tev from this parish.
May 18th, 2012, 12:51 am
By 'eck lad,
hope you're not going for the hat trick, only one more to go for 3 in a week. :lol:
May 18th, 2012, 1:14 am
