Reply to topic  [ 27 posts ]  Go to page Previous  1, 2, 3  Next
 Is This Normal?
lovin' the snatch
Post Re: Is This Normal?
ok so i cant remember when i last checked mine, it would have been quite some time ago... and since then i've probably done about 10k.... well i've done 4,000 miles since August....
almost all of that up untill last week was up and down the M1 doing 40 miles a day at 6,000rpm....
i get the feeling my valve clearances definitely need checking!
|-|-' 602 For Life :)
Keep Them Looking Standard.
1979 Myosotis Blue Dyane6
1986 Sunrise Red 2cv6
October 25th, 2011, 9:57 pm
Indeed :) ..cheers Ken looks like mine are due for a look then :)
October 25th, 2011, 10:10 pm
Can't say the tappets were ever checked, let alone adjusted, on my always caned original engine that got to 205 thousand miles in one piece-currently awaiting some fettling at Spanners Towers. It will return.
October 25th, 2011, 11:15 pm
Jonathan,
are you quite sure about that? :lol:
Peter Cross at Tibberton,Worcester, next week. When it goes in for those jobs to be done,I'll have the car serviced and will have the heads torqued up(or is it down?..well tightened then) and have the tappets adjusted as in the words of Peter.."It's very quiet for a 2cv engine". The tappets are too tight.
October 25th, 2011, 11:38 pm
:oops: :lol: ;) okay, maybe once in 135 thousand miles....not every 5 thousand. :D Ken, you have a better memory than me, which to be fair, isn't exactly difficult :lol:
October 25th, 2011, 11:52 pm
I fo mine every 3 k and half the time there ok
It's such sn easy job to do,
Make sure the engines hot and dump the oil while your doing it
October 26th, 2011, 2:40 am
"Make sure the engines hot and dump the oil while your doing it"
Aren't you supposed to measure the gap on a cold engine? - Surely if you measure when hot, this will give a false reading and they will be very sloppy when cold? - as the metal expands the tappet gap is there to allow for the pushrod to move without being too tight.
October 26th, 2011, 7:24 pm
I though Haynes manuel said hot or have I got it the wrong way round :lol:
October 26th, 2011, 7:26 pm
James its an expansion gap so it should be done when cold.
October 26th, 2011, 7:36 pm
Jameswallace wrote:
manuel said hot :lol:
October 27th, 2011, 1:58 am
