View unanswered posts | View active topics It is currently May 2nd, 2026, 7:35 am
Reply to topic  [ 101 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 11  Next
 B7 plugs?
Post Re: B7 plugs?
Can't honestly say I've ever noticed the difference between Equiums or NGKs, I've towed boats, thrashed cars at 75 and pootled round town on both.
September 20th, 2011, 10:53 pm
Post Re: B7 plugs?
Another +1 on NGK 7HS plugs (might even stretch to 8's). I used them for years and never had any problems and I like to 'exercise' my engine ! If you have trouble getting them, try your local m/bike shop.
Tim
Teesside
September 20th, 2011, 11:07 pm
Post Re: B7 plugs?
FourStar wrote:
Have to admit that, after 90,000 2CV miles in 3 years using only NGK B6HS, I've found them to be spot on & faultless - be it town driving or a sustained 70mph..
Amazed that one could fail so epically!
Ive never had a problem with ngk's,
However the equem plugs did let me down,
I use b6's in mine faultlessly
September 20th, 2011, 11:09 pm
Post Re: B7 plugs?
I've been using B7HS in 8.5:1 engines and B8HS in 9.0:1 engines for over 15 years.
With B6HS, there could be problems with 'running on' after the engine was switched off, which indicated that their heat range was too hot.
p.s. http://www.eyquem.com/
Nul points for 'Equiums', 'Equim' or 'equem'... :roll:
September 20th, 2011, 11:21 pm
Post Re: B7 plugs?
Ken
Sorry for the spelling mistake ;)
Odd you mention running on, because however spot on the timing is, it runs on a fair amount of the time
I've never tried b7hs, next time I'm short of plugs I may try them based upon the above opinions
September 20th, 2011, 11:30 pm
Post Re: B7 plugs?
I've only ever used NGK plugs in mine (probably just because they're easier to get hold of), have never replaced a pair as early as recommended, and have never had one fail in a car, or even show signs of deteriorating. That does mean though, that I end with a small collection of used spark plugs, including some Bosch and Eyquem that have been in cars when I've got them, which then tend to get used up in ratty two-stroke bikes. Old Eyquems seem to be absolutely hopeless for this, and the only Bosches I've got came out of the Dyane boot, so the fact they work at all after I've dug out all the rust around the insulator is pretty impressive, but NGKs seem to last very well even second time around.
That said, I've just about ruined all the old plugs I have now, so if anyone else can't bear to throw anything away, and has a little stockpile of almost worn out sparkplugs doing nothing, let me know!
Also on the subject, does anyone have a link to an idiot's guide to heat ranges, as it's something I've never really got my head around properly?
September 21st, 2011, 8:41 am
Post Re: B7 plugs?
Not very good photos i'm afraid as taken on my phone but you should be able to make out the difference between the plug that came out of the nearside
and the one that came out of the offside
After not even 100 miles!!
September 21st, 2011, 9:11 am
Post Re: B7 plugs?
I have heard of problems with ngk's of eBay.. But they (after the problem) where believed not to
Be genuine
September 21st, 2011, 9:40 am
Post Re: B7 plugs?
@ Luke,
not an idiot's guide, but a very good one...
http://www.ngksparkplugs.com/tech_suppo ... ugs/p2.asp
Interesting stuff on page 4, specifically concerning fuel type and ignition timing.
Always remember that plug manufacturers like to set a little trap for the unwary, with NGK's heat range being 'the higher the number, the colder the plug', whereas Bosch and others use the reverse.
@ emu_p,
pity that the photograph is so blurred, since that looks like physical damage.
The only time I've seen an earth electrode that shape was when the plug had been dropped... ;)
September 21st, 2011, 9:48 am
Post Re: B7 plugs?
Well I had a new Eyquem doing this after 2 weeks. Only one for a long time. Sold heaps without any problems, same for NGK B6HS. Naturally odd one with fail one way or another from time to time. Won't speculate why but one can't always blame the plug.
September 21st, 2011, 11:47 am
Users browsing this forum: No registered users and 118 guests
