View unanswered posts | View active topics It is currently May 1st, 2026, 11:30 pm
 Doing the rear brakes
Post Re: Doing the rear brakes
If you're changing the rear brake cylinders - which is a good idea, while you're in there, since they're not expensive - you might also need to change the rear brake pipes as well. The union at the cylinder end often rusts up to the point where it's difficult to get the pipe out without breaking it.
August 1st, 2011, 2:49 am
dont the pipes go up the axel in a higgaldy piggaldy motion? after going up the swing arm? i dont fancy changing the brake pipes in the axel, is there a join before there? i was considering it but i didnt want to open up some more worms..
August 1st, 2011, 9:18 am
http://www.ecas2cvparts.co.uk/brake-pip ... p-828.html
http://www.ecas2cvparts.co.uk/brake-pip ... p-829.html
August 1st, 2011, 9:25 am
That's right. They're a bit of a bugger to change. You might not need to change them, but it's worth having a look at them before you start removing brake cylinders since if they're rusty you'll break them when you undo the cylinder union. In fact, if they're rusty, they need replacing anyway ... :)
August 1st, 2011, 11:22 am
hmm im just cautious as i dont want to be lumbered with a difficult job of changing the pipes!!
August 1st, 2011, 2:37 pm
James,
I have the tools etc (on loan to Ben at the moment), you are welcome to borrow them if you want to.
August 1st, 2011, 10:32 pm
