View unanswered posts | View active topics It is currently May 6th, 2026, 10:37 am
Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 slowbo no run , job done all sorted
Captain Slow
Post Re: slowbo no run
did the gravity thing and still no run , it will run when we put fuel in top of carb put then dies
fuel pump is new and fuel is getting to carb ,when we turn it over by hand it wants to run but just wont !!
Idle jet is in
July 12th, 2011, 10:34 pm
Idle jet is in
Then the jets are blocked. Take them all out and blow them clean. Voila
July 12th, 2011, 11:07 pm
Captain Slow
had all the jets out ,must be the 1 that pagey blow out then :x il take carb off and give them all a clean
July 12th, 2011, 11:16 pm
Lungs are no good, you need to get some compressed air on them. If it fires up dribbling petrol down the carb you can discount all ignition issues.
I bet Steve took his glasses off to look at the jet :lol:
July 12th, 2011, 11:24 pm
oboe,
if you work the accelerator pump lever manually, is fuel being squirted from its jet, which protrudes into the carb throat?
If that's not happening, there's not enough fuel in the carb bowls.
July 13th, 2011, 12:51 am
Captain Slow
Post Re: slowbo no run / engine now run's , gearbox/ clutch no wo
cheers griif / ken
striped the carb ,gave it all a good blow out ,now its running good
got it all back together ,to go for a test run , put foot on clutch ,tryed to go into 1st gear and it just grinds big time ,and in all the other gears , dont want to force it into gear , as sounds like its going do break something
will having been sat for 14 months done something to the clutch ???
July 13th, 2011, 6:55 pm
oboe wrote:
cheers griif / ken
Sound like the clutch plate is stuck to the flywheel. Quite common when a car is left.
Try this. Sit in the car engine not running. Put it in gear [forward or reverse which ever way the car has some space to move] foot on the clutch, hand brake on, try to start engine. There might be a bit of a bang as it comes unstuck but that usually cures the problem.
July 13th, 2011, 7:08 pm
clutch could be stuck ? will it go into gear with engine off? if so, does it start ok without jerking forward?
July 13th, 2011, 7:10 pm
oboe,
almost there...
The clutch plate has probably rusted onto the flywheel, so there a couple of things to try, but you'll need some space for this first one.
Start it in first gear, accelerate to about 15mph and decelerate with your left foot holding the clutch pedal down all the time.
The more 'kangarooing' the better.
Repeat as necessary until the clutch decides that it may as well play ball... :lol:
oboe wrote:
cheers griif / ken
July 13th, 2011, 7:11 pm
Captain Slow
Cheers all , will have a go tomorrow . off to see some pikeys now for paella :lol: :lol:
July 13th, 2011, 7:32 pm
