View unanswered posts | View active topics It is currently May 1st, 2026, 4:29 pm
 Oil on clutch plate
Post Re: Oil on clutch plate
Given that the van currently has a stupid graphite clutch as long as it hangs in till the new wngines built, would it be possible for the hybrid to be fitted with a later type clutch?
May 18th, 2011, 1:11 pm
It's not the clutch that's graphite, just the wanky bearing.
May 18th, 2011, 7:23 pm
Sam Ecas sell a 'later type' clutch that has the holes for the bolts of a spring clutch?
Correct me if I'm mostaken
May 19th, 2011, 9:12 am
OK, "M-I-S-T-A-K-E-N".
May 19th, 2011, 9:32 am
ok
Its "mistaken"
that's you "corrected"
edit- :lol: :lol: :lol: too easy. actually perhaps its "most taken" ie he really likes it?
May 19th, 2011, 9:33 am
You're right, but it wouldn't fix Sam's problem, which is to do with the strange and rather terrible clutch fitted to really early cars. Both the three spring and diaphragm clutches have a proper release bearing, which spins when it comes into contact with the clutch springs. Sam's car has a circular piece of graphite which is static and releases the clutch by squealing at it. :)
May 19th, 2011, 3:42 pm
Can I do anything about this? Like a new clutch? What would mate to the gearbox?
May 19th, 2011, 7:33 pm
I've got what appears to be a reasonable static clutch in the shed. It's the one out of the Ami. If it's any use to you you're welcome to it, but I don't think it'll be any better than what you've already got. The only way to get a later clutch is to fit a later gearbox, as far as I know. And I presume you don't want to do that.
May 20th, 2011, 6:34 am
Not really wanting to change the gearbox... cheers RT, I'll see what mines like so hang on to it!
May 20th, 2011, 1:21 pm
I've never looked at one so I might be talking out of my arse, but it must be possible to modify stuff, release arm, gearbox, or the bearing itself, to use a later type bearing.
May 20th, 2011, 9:45 pm
