View unanswered posts | View active topics It is currently May 1st, 2026, 2:54 pm
 Wheel wobble... or something?
Post Re: Wheel wobble... or something?
its ok james just dont go to france, they turn left when going round roundabouts so stay in this country and you will be fine ;)
April 6th, 2011, 6:48 pm
Have you checked the kingpin you had changed recently? Not sure it would cause this kind of problem but maybe worth looking at seem as its been fiddled with.
April 7th, 2011, 12:43 am
Or that this part isn't working loose from the hub carrier?
< http://www.ecas2cvparts.co.uk/track-lev ... -1222.html >
Fwiw, I don't understand why folk undo these when changing a kingpin, it's only necessary if you've got to disconnect the hub carrier from the track rod for some reason.
The only time I've found that necessary was when someone had hammered the lower threaded plug into place during a previous kingpin change... :shock:
April 7th, 2011, 1:08 am
Dry sliding joint in the driveshaft?
John Jordan
April 7th, 2011, 9:41 pm
