2CViking
 Re: Setting Valve Clearances
So all break downs are related to valve clearance
| March 3rd, 2011, 1:51 pm |
602
Joined: July 21st, 2010, 7:12 pm Posts: 859 Location: Chatenet, France
toomany2cvs wrote: 2CViking wrote: Valve clearance 0.20 not 0.25  A tappy tappet is a happy tappet. Agree, and its a nice phrase too, has a sort of rhyme to it. 0.25 for me all the time.
| March 3rd, 2011, 1:55 pm |
twofifty AZU
2CViking wrote: So all break downs are related to valve clearance  Absolutely, get the valve clearances right and your chassis won't break, your coil and points will last indefinitely, rust is but a distant memory, your hood will be perfectly water tight, your king pins will never chatter, your battery will be charged at 14.3 volts precisely and you never need change the oil again as long as you use a Purflux oil filter.
| March 3rd, 2011, 1:58 pm |
2CViking
Please explain why 0.25 mm is better than Citroens recommendation of 0.20 mm Do you know what happens changing to 0.25 mm
| March 3rd, 2011, 2:01 pm |
602
twofifty AZU wrote: 2CViking wrote: So all break downs are related to valve clearance  Absolutely, get the valve clearances right and your chassis won't break, your coil and points will last indefinitely, rust is but a distant memory, your hood will be perfectly water tight, your king pins will never chatter, your battery will be charged at 14.3 volts precisely and you never need change the oil again as long as you use a Purflux oil filter.  Love it.
| March 3rd, 2011, 2:08 pm |
twofifty AZU
2CViking wrote: Please explain why 0.25 mm is better than Citroens recommendation of 0.20 mm Do you know what happens changing to 0.25 mm  The camshaft has a base circle. You measure the clearance directly opposite the point of the cam, at the lowest spot. The base circle is ground slightly oval so that as the camshaft rotates it initially lifts the valve gently before opening the valve completely. By increasing the valve clearance very slightly it takes fractionally longer before the follower contacts the base circle and begins to open the valve. Therefore the valve stays closed fractionally longer which allows the head of the valve to transfer heat to the cylinder head. The head of the valve can't really shed heat when it is open. Hence the tighter the valve clearance the greater the risk of a burnt out valve. Edit Bear in mind that we don't have leaded fuel any more, the lead acted as a lubricant on the valve seat. If the head of the valve gets too hot it starts to weld itself to the valve seat as the valve snaps shut. When it is opened again the weld is broken and microscopic bits of valve seat get stuck to the head of the valve. That means the valve seat starts to wear. A phonomenon known as valve seat erosion. The lead used to prevent this. Aditionally modern fuels run hotter than the stuff we got years ago.
602
Anyway Cloudy, beside the controversy of 0.20 and 0.25 the pictures are excellent and should be made a sticky, if that's the right term.
| March 3rd, 2011, 2:13 pm |
Viking, out of idle curiosity, why did this cylinder head have to be removed? http://www.citroenclassic.org.au/Galler ... 80_jpg.htmAnd why was an electronic ignition unit being fitted, instead of a replacement set of advance weights? http://www.citroenclassic.org.au/Galler ... 85_jpg.htmken. 2CViking wrote: So all break downs are related to valve clearance
| March 3rd, 2011, 2:18 pm |
2CViking
Oil feeding pipe snapped. Push rod seal leaking badly Ignition fitted as a test (dust and moister (creek crossings)
| March 3rd, 2011, 2:35 pm |
2CViking
Burning a valve or a seat is more likely to come from, worn valve guides, wrong ignition or wrong mixture than changing the valve clearance less than 0,05 mm
| March 3rd, 2011, 2:38 pm |
Users browsing this forum: No registered users and 204 guests |
