View unanswered posts | View active topics It is currently April 30th, 2026, 7:12 am
 Identify a gearbox?
lovin' the snatch
Post Re: Identify a gearbox?
ahh ok, cheers :) i've got a spare gearbox, which came with Lily.. all them years ago.. it also came with a spare engine which was from a dyane and a load of spare bits and pieces.. all which were dyane... so i just assumed the gearbox was too! will have to have a closer look at it when i get the chance!
|-|-' 602 For Life :)
Keep Them Looking Standard.
1979 Myosotis Blue Dyane6
1986 Sunrise Red 2cv6
March 8th, 2011, 4:49 am
see above.
just in front of the splines is a plain bit of the shaft if there is a single groove in it its a dyane box, if its plain then is a 2cv.
sean
March 8th, 2011, 8:53 am
I do it always like this, and it works:
Turn the input shaft (where the flywheel fits).
When you can turn it 21 times and the wheels have made 1 revelution it's a ami 8 or dyane 6 gearbox.
When you can turn it 23 times it's a 2cv 6
Can you turn it 28 times before the wheels are making one revolution it's a 2cv4 gearbox........
These are the most commen ones others are possible Mehari, aks400 but I don't now them out of my head. Then you got the old gearboxes with the gearlever at the end of the box fitted with 4 bolts you can do the same trick with them. The only thing about them I now of is that there is one gearbox frpm an ami 6 witch is even longer then a dyane 6 gearbox. Less revelutions
When you count put it in 4. Gear and make shoore both wheels are turning equaly...........
Good luck.
March 8th, 2011, 10:29 am
Ipgo,
are you sure that it's 4th gear, as 21.5, 22.3 & 28.7 turns correspond to 1st gear for each type of 'box... ;)
March 8th, 2011, 11:07 am
G
Ipgo,
your so right it is first gear........ Slip of my mind;-)
March 8th, 2011, 11:13 am
Users browsing this forum: No registered users and 108 guests
