My clutch can't decide if it's buggered or not
 Re: My clutch can't decide if it's buggered or not
Paul, if a nut is loose or missing, it's not so much that the input shaft won't be in line, more that the bellhousing will distort when the clutch pedal is depressed. Work out the two-stage leverage multiplication at the pedal end and fork end to understand why... ken 602 wrote: Hmm, Ken does have a point. If the box isn't mated correctly to the engine, i.e. nuts loose or missing [seen many times] then the input shaft won't be in line. Could cause the problem and worth a check. One liners, where do they get you?
| February 16th, 2011, 3:15 pm |
602
Joined: July 21st, 2010, 7:12 pm Posts: 859 Location: Chatenet, France
ken wrote: Paul, if a nut is loose or missing, it's not so much that the input shaft won't be in line, more that the bellhousing will distort when the clutch pedal is depressed. Work out the two-stage leverage multiplication at the pedal end and fork end to understand why... ken I did know that but thought I would keep the two stage lever calculation quiet.
| February 16th, 2011, 4:49 pm |
knightley
Joined: June 19th, 2010, 8:40 pm Posts: 761 Location: Kingswood, S.Glos.
602 wrote: ken wrote: Paul, if a nut is loose or missing, it's not so much that the input shaft won't be in line, more that the bellhousing will distort when the clutch pedal is depressed. Work out the two-stage leverage multiplication at the pedal end and fork end to understand why... ken I did know that but thought I would keep the two stage lever calculation quiet.  It will depend on whether it's a top nut or bottom nut missing. That's 2 calculations to do.
_________________ John Jordan
| February 16th, 2011, 6:31 pm |
Russell
Nuts are fine, none missing broken loose or otherwise. Guess I'll stick a clutch and bearing in it. Thanks for your ideas though.
| February 16th, 2011, 8:41 pm |
602
Russell wrote: Nuts are fine, none missing broken loose or otherwise. Guess I'll stick a clutch and bearing in it. Thanks for your ideas though. Let us know what you find.
| February 16th, 2011, 8:44 pm |
Users browsing this forum: No registered users and 60 guests |
