View unanswered posts | View active topics It is currently May 1st, 2026, 4:29 pm
 Tell me about M4 Engines
Post Re: Tell me about M4 Engines
http://snail.s4.bizhat.com/snail-ftopic ... c-210.html
January 8th, 2011, 10:49 pm
Really? Daras Rich's 350 has a similar satup
I think Daras's 350 is "just" a late AK B - so totally normal M28/late gearbox brakes setup. IIRC, the only other M4 350 in the UK is Pete & Bev's "Stimpy" AKL Weekend.
January 9th, 2011, 11:49 am
sam,
I'd reckon that the lack of a filter is their achilles heel, What are peoples experiances? What's maintenance like?
[/quote]
The biggest achilles heel (in my opinion) is that those car's haven't any oilpressure indicator, so there is no indication when oilpressure drops/is gone (less of oil), so you have to check oil level almost for any ride (daily bases)..........
Maintenance cost as much time as a new 602 only make more oilchanges (3000/5000 km).
But these are very fine engines, especially torque at low rpm, especially engines with the big single valve carburator (1966/67) they have more torque at low rpm 1500/3500 then a 2cv6 engine.........
January 9th, 2011, 12:28 pm
Which Hetty has - it's a late Ami 6 M4 engine - big valves, high compression, big carb. Nominally 28bhp, IIRC.
January 9th, 2011, 1:42 pm
Adrian,
wonder if that should be 'higher' compression, as 7.75:1 doesn't really count as being 'high compression' except in relation to 7.5:1... ;)
Those jampot carburettor don't seem to have been a huge success, judging by the short period during which they were fitted.
Still, there's one amongst the boxes of bits here, so I'll do my best to get that up and running again.
@ Ipgo,
I suspect that the 'higher torque at lower rpm' characteristic may be closely linked with the camshaft profile and timing, so yet another reason to hope that the bottom end of an M4 engine can be retained? :)
January 9th, 2011, 3:00 pm
All things are relative! It's not so much as a compression stroke as a gentle hug of the mixture.
Probably more because the M4 was superceded by the M28 than anything else - although it should be noted that it's bigger than the carb that Citroen were fitting to lower-spec DSs at the time!
January 9th, 2011, 4:47 pm
twofifty AZU wrote:
The basic difference is that the M4 uses a different manifold to the M28. The flanges are horizontal rather than angled.
talking about M4 manifolds, do anybody know if the manifold is the same on M4 425ccm and 602ccm?
Reason why asking is, that the preheating camber on the manifold on my M4 602ccm/ Dyane D6, has seen better days. The other manifold I have is in worse condition that the one fitted, but I know were to find some from 425ccm engines.
I suffer from citrofilis ..... what's your excuse?
January 9th, 2011, 7:13 pm
425 and 602 do not share same mainfold, just look at the carby, two completely designs
January 9th, 2011, 7:15 pm
True, but...
There's at least three different manifolds for M4 602s.
- Dynamo & small carb
- Alternator & small carb
- Alternator & big carb
But they're detail differences - generator mounting & carb flange. Rather more fundamental is the shorter stroke on the 425...
Shans - the hotboxes all rot out. They're easy enough to weld, though. They're just sheet steel, and the head mounting faces are flat, so just bolt it to something very solid to prevent distortion (Louis Barbour's big workbench has the bolt pattern drilled into it!), and patch away.
If you're really stuffed, I think I've got a spare big carb/alternator manifold or two somewhere. I just bought 'em any time I saw 'em.
January 9th, 2011, 7:19 pm
sounds good :mrgreen:
Mine is the alternator and big carb ones, due to centrifugal clutch and 12volt alternator.
The shitty one, we have tried to weld, but from factory they have used brass or something to seal the welds with.
Therefor you just can't weld in it.
January 9th, 2011, 9:30 pm
