View unanswered posts | View active topics It is currently April 29th, 2026, 3:56 am
 Honing Barrels
Post Re: Honing Barrels
Jono wrote:
I borrowed the honing tool off a local garage.
What type did you use? I've seen someone use a tool with arms that spin outwards when used in a drill, but after a quick google, it seems there are different types
June 24th, 2010, 7:59 pm
Before you go ahead, measure the barrels with a plug gauge to determine the ware or use the new rings to find out. Place the new rings inside the barrels and measure the gab with feeler gauge. If gab is more than 0.35 mm the barrel is too worn in my opinion. Sometimes a new piston and barrel set is a long term better solution. How many miles has the piston and barrels done (city or country driving)
June 24th, 2010, 10:37 pm
Yes hone the barrel if its not too worn, the most wear occurs at 20 mm or so from the top of the barrel
as you are not running in the crank or cam you need to load up the rings to bed them in
http://www.citroentuning.de/doc/How_to_break_in.pdf
June 25th, 2010, 7:52 am
