View unanswered posts | View active topics It is currently May 1st, 2026, 8:52 pm
Reply to topic  [ 59 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 right.. no debates, no arguments just honest opinons please!
Post Re: right.. no debates, no arguments just honest opinons ple
Errr,
doesn't it takes a bit more than simply connecting the unit to an ignition coil to reprogram a 123?
Don't remember anything about this from when I did the proofreading for the English version of the 133 instructions, only that the black and yellow wires weren't to be connected to the coil to power it up until after the 'static timing' setup had been carried out. :roll:
( p.s. If I did ever decide that 'points + Boyer Bransden' didn't work just fine for my cars, I'd probably go for a Lumenition setup. )
rebel2cv wrote:
123, I've fitted it to mine and never looked back, a lot of people wire it all up and then try to set the timing, this gives the pcb a memory and makes it useless, connect it up as the instructions tell you to don't put the last wire on until timing is set.
October 26th, 2010, 2:07 am
lovin' the snatch
i doubt a new 123 could be any more faulty than a brand new condensor i got last week... that was a day after fitting it...
|-|-' 602 For Life :)
Keep Them Looking Standard.
1979 Myosotis Blue Dyane6
1986 Sunrise Red 2cv6
October 26th, 2010, 2:15 am
Joe,
Lumenition is an opto-electronic system, using an infra red emitter and detector as a switch and it retains the ignition advance mechanism.
123 uses a magnetic system (Hall effect) and controls the ignition advance electronically, or it does until it's cooked by over-voltage or a cold bath... :lol:
October 26th, 2010, 2:19 am
Got Lummie on my car.
It was fitted 13/14 [?] years ago.
I've never touched it since.....although Ken re-set the timing for me when he rebuilt my engine [new barrels,heads & pistons] last year.
I seem to recall reding somewhere that 123 does'nt like being "jump started" with another battery & jump leads .....I dunno if its true.
But I've neve had any probs with my Lummie system.
T.
2CV6 Special [Red]
C4 VTR+ Coupe [Black]
October 26th, 2010, 2:31 am
lovin' the snatch
right...
well i certainly dont drive through any deepwater, and touch wood... i havent had any problems with my battery! this cars got a lovely electronic voltage regulator which so far hasnt fallen off onto my now non existant swan neck and melted... :P so i definately havent and dont expect any battery problems!
i am thinking 123 purely because there are less moving parts still left on the car, as you loose the whole advanced weights set up with 123!
October 26th, 2010, 2:47 am
Gay_Joe wrote:
we have been here before...
im buying electronic ignition for pops :)
Gay_Joe wrote:
right...
Pops is the car or yer dad?
if its your dad why not ask him which he would prefer?
October 26th, 2010, 7:48 am
Points.
October 26th, 2010, 8:26 am
Points.
+1. Can't understand why anyone has a problem with them, myself.
October 26th, 2010, 8:33 am
[dhquote="Gay_Joe"]
i am thinking 123 purely because there are less moving parts still left on the car[/quote]
Much less, when it breaks! ;)
I've got points and a homemade Boyer-Bransen lookalike (from a Maplin kit) on mine. Simple, and even if I'd replaced the points at the time as well, the whole lot would have only cost me £25.
It's been on there 6 months now, and I ran one on my previous car for a few years. No problems at all with either of them, but if it ever does fail, it would only take a couple of minutes of messing around with connections at the coil to set it back to standard.
October 26th, 2010, 9:27 am
in fairness joe, this is one of those topics, where you will always get mixed reviews and opinions, a bit like rust preventers, everyone has there fair share, like i said, i prefer points because its simply all ive used and i havent had 123 or lum, and for the price of 123 i dont want to try and see if i like it if you get me ;)
if it were me making the decision? well i started a topic a while back about the same thing, i decided to stick with points. why did you replace your condenser? had the old one packed up? did you replace both points and condenser at the same time??
if your car is frying condensers why wouldnt it fry a 123?? if you see my angle,
JUST a suggesiton so dont hunt me down ;)
October 26th, 2010, 9:41 am
Users browsing this forum: Bing [Bot] and 99 guests
